Muller Dynamo
0 Members and 23 Guests are viewing this topic.
Groundloop
Quote from: romerouk on May 06, 2011, 05:01:50 PM
:) I tought u use something more professional.
I call myself an IT engineer and I don't recognize something simple like that... bad for me :)
I have edited the previous post to you
I do use other design programs also. But the Paint program is good enough for small and simple circuit designs.
Once you master the copy/paste and zoom in/out then you can make drawings very fast. :-)
I have moved the switch and updated the drawing with a 47000uF 25V cap.
GL.
romerouk
@woopy
good to see you arround.
Regarding the stranded wire:
Some time ago in a Bedini project I have built 2 identical coils but one with normal wire and another with stranded wire.I was using this coils to collect the power from the rotor powered with a Bedini standard circuit.Same core same wire diameter, all the same...
The results at that time(no load):   normal wire output was 9.2 volts
                                                stranded wire output was 12.3
since then I have always used stranded for most of my coils
it is easy to do the same experiment like me, actually it would be nice if someone else will confirm this.
I always try everything myself, I don't take all info I found as granted.
If I was wrong I would like someone to tell me.
@Groundloop
one more change to the drawing: input cap 47000uf
toranarod
Quote from: romerouk on May 06, 2011, 05:14:12 PM
@woopy
@Groundloop
Thanks for the info on the wire
thats all I need to know that is a good reason
cheers
plengo
Quote from: toranarod on May 06, 2011, 04:05:13 PM
this is to important to pass up
I am going to build one, I am not stopping my current project as it will work
as well. will have two motors on the go.
keep every body posted
cheers
Me too!
@Romero.
Excellent work man. I will replicate this too.
Would be possible to take good close up pictures of your motor of every detail and post it? sometimes pictures can answer a million questions and also helps with documentation.
Many thanks,
Fausto.
penno64
Hi all,
How wonderful it is to see so many going for it.
I dont know if you are religeous Romero but, GOD BLESS YOU!
Regards, Penno
p.s. Rod, I thought you would like this.
