Muller Dynamo
tinu
Quote from: hartiberlin on May 18, 2011, 07:19:59 AM
hi All,
I just got a reply from RomeroUK about the Recovery diode.
He wrote to me:
"One diode is on the PCB of one of the driving circuits, not the closest one,
the other one
Used just in the first movie."
I will make a new circuit diagramm for this first movie and update the PDF soon.
Regards, Stefan.
Hi Stefan,
If you are still in contact with Romero, please kindly ask him to state that the cordless drill (probably a DeWalt, judging by colors) that can be seen at 15’56” (in the main OU video) and it’s charger has nothing to do with the setup.
I’m sorry but for me to feel confident without clearing this issue would be very difficult because the drill is placed way too close to the motor and it has a convenient voltage and power rating. Besides, usually those plastic tables have a hollow leg (for umbrella) terminating with a removable plastic lid, so it is very easy for anyone to be suspicious, especially because the under setup can not be inspected in the movie neither the multitudes of wires leading there.
You can call me paranoid but not the others ;)
Oh, nul-points can tease me more; I started to like it. :)
Many thanks,
Tinu
chrisC
Quote from: Crapola on May 18, 2011, 08:26:27 AM
ChrisC, I remember Romero saying that it is important that the rotor should be thick enough so that it should not bend. Do you think your rotor will be stiff enough after the magnets are added? Thanks for the info so far.
Crapola
@Crapola
Tabplastics have 2 thickness size for their precut circular acrylic plates. I use the thicker ones and they are solid enough. My problem is not with the plates, it is with trying to mount the VCR drive/bearings to sit flat because of two protruding screws just 1mm beyond the bottom surface and I don't have the correct screwdrivers to remove them!!
cheers
chrisC
Tudi
@woopy : already posted this : http://www.ostfalia.de/export/sites/default/de/pws/turtur/DownloadVerzeichnis/Series-english-5Articles.pdf
page 24 : "In any case we see, that zero-point-energy converters improve their efficiency and power, as soon as the resonance frequency of the oscillating fields is increased." + "In order to convert zero-point-energy into any classical type of energy, there must be an oscillating (electric, magnetic or gravitational) field inside the converter ". + "Power can only be extracted from a motor, if there is some (mechanical) resistor, and not as long as it is running without any force" + "the zone of maximum power-extraction from the quantum vacuum has some certain width. If a zero-point-energy motor can be operated within this range, friction will be just a little bit too weak to stop the engine" + " a capacitor and a coil have to be adjusted in a way, that the frequency of an electromagnetic oscillation corresponds to the frequency of a mechanical oscillation. It depends on the precision of this adjustment, whether zero-point-energy is converted or not."
Ofc this is just some random theory. "New theory", but we did observer as romerouk device speeded up as load increased = increased frequency. And this device is indeed about colapsed / created magnetic + electric fields at increased frequency.
JouleSeeker
Quote from: i_ron on May 11, 2011, 02:41:49 PM
Romero,
I hope you can still read here?  Just wanted to say thank you (again) and that we will do our best to vindicate you by carrying on this great work.
"They" may have waited too long to suppress this, the genie is out of the bag. Anyway, we will do our best.
We understand fully. what you said, why you had to do what you did. We are with you in spirit.
Ron
Another from Ron:
QuoteSterling,
Thank you for posting that letter from Romero.
The "system" strikes again. His device has been taken away and destroyed. He is not to do research anymore.
There is only one conclusion.
Ron
I agree with Ron -- we support you, Romero.
If you can let us know somehow WHO it was that threatened you, as specific as you dare, this would be of help to the rest of us who may face similar threats.
Thanks so much for your work -- hope you are still reading this thread and can contribute from time to time.
Thaelin
   Just out of wanting to know, if someone does replicate, are we going to see another shark feed?
thay
