Muller Dynamo
0 Members and 18 Guests are viewing this topic.
khabe
Quote from: Staffman on May 18, 2011, 03:55:37 PM
lasersaber great work!!! Just to reiterate, that load you put on that coil did not change the rpm? Way cool.
About what kind of load you are speaking? Amperage, please ::)
Bulb just merely glows,
cheers,
khabe
Cherryman
Quote from: khabe on May 18, 2011, 02:41:59 PM
but at least for me he did nullify this "possibility" himself when said that he can do the same with RC motors. - in to RC motor you cant fill nothing from this "very unique design", Im very sorry, but unfortunately this is like that.
cheers,
khabe
Hi khabe
My understanding of the words of Rom concerning the RC engines is not that he could produce OU with the engine on its own.
I understood that they could be used as a driver for the setup, so you do not need the driver coils.
In other words. Due to the efficiency and RPM/power of those motors , they are suitable to connect to the "dynamo" as the driving engine.
Quote from: romerouk on May 07, 2011, 11:22:21 AM
First picture shows 2 motors that are almost OU when comming from factory.They come with Muller arangements inside already.I have left info about them but looks that it was missed.
This is probably the easiest way for people to try Muller's config.You don't get a lot out but more than in.I have tested it with another normal dc motor to drive the shaft.Come on people, this one is cheap, search on ebay for it.You need to redo the windings again to have sections of 2 coils next to each other forming one set, coil up and coil down from my larger device.I used 0.3mm single wire.
Second pic shows more parts that are going to be used to the next device.
Edit:  Oh wait...  it seems the other way around...  Damn.. this beats Sudoku  8)
baroutologos
Quote from: lasersaber on May 18, 2011, 03:26:08 PM
Here's an update showing my current progress.
Video here: http://www.youtube.com/watch?v=2KaVcmXyktw
Hat off! You surely know how to make a replica!
k4zep
Excellent work Lasersaber!!!!!
Ben K4ZEP
nul-points
Quote from: Cherryman on May 18, 2011, 04:05:10 PM
yes, that's true - but Romero also hinted at modifying the contents of the motor to make it more like a Muller config
this would have involved inverting alternate coils to become say the "top" half of a pair whilst the unchanged coil would become the "lower" of the pair
of course the rotor mags rotate around the periphery, so they bridge the gap between the "top" & "lower" on the outside of both coils, not inside/between as in his own device
...and of course, as khabe will tell you, (only the once, if you're lucky) it can't be done! (hi khabe)   ;)
hth
np
http://docsfreelunch.blogspot.com
