Muller Dynamo
nul-points
Quote from: khabe on May 18, 2011, 04:59:06 PM
The only thing we can do is await a new Messiah arises  ::)
khabe
Hail King Khabe, the omniscient!!   ;)
(can i be your court jester?  pretty-please?)
khabe
Quote from: woopy on May 18, 2011, 05:09:45 PM
yes Lasersaber
well done ;D
If i can give an advice , do not try only one set of coil test with the top magnet as Khabe suggested, because you will retrieve the cogging effect, which will èrobably  bias the result. Now i am strongly thinking that the beast can't be separated in pieces, it must work as a unity to be stronger than the unity
In your video, due to the noise, i am not sure but , i think that you utilise wire litze is it OK ?
Another time bravo for your replication it is very encouraging.
@ Tudi thanks for the link to Prof Turtur very intreresting for the future improvement if we manage our basic replication. And for the RMS instrument i don't know the lost in low Voltmeter because at the moment i do not use this fonction, i only read the line on my scope and make estimations, to approximate if we are totally out of the "plate " as in bon français or if there is something to examine.
@ e2matrix
Thanks for the comment it was simply an idea.
I rewatched the video  of Thane and could see that hes rotor
@ Khabe
can you please stay on the thread, i know that Romero spoke of modifying  R/C motor  but i think that he was trying to make a diversion when he saw the pressure comming.
I think it could be very interesting to investigate those R/C modifications but on a dedicated thread.  Because this thread is alrewady very immense and if we divert too much we will be lost in a pletore of undedicated post .  That' my proposal.
I stay on the thread - this is about Rom´s replication and there is very necessary to follow all what he has spoken.
I can be  quiet, no problem, but cogging is already reduced with 8 pole/9 coils configuration, about what cogging you are speaking "will retrieve the cogging effect"  ??? Coil top magnet locates as far as 35mm from rotor magnets, dear woopy ::)
Diversion ;D
cheers,
khabe
nul-points
hi Laser
if you're still around at the moment, could you say a quick few words about the drive arrangement?
did you follow Romero's setup for the two sensor positions, use basically the same circuit, etc?
many thanks
np
http://docsfreelunch.blogspot.com
khabe
Quote from: nul-points on May 18, 2011, 05:24:35 PM
Hail does not insult me, my dear friend.
Take a break and read one time more all Rom´s posts, at least 20 pages but carefully,
And think,
Have a nice time,
cheers,
khabe
nul-points
khabe
'Hail' is not intended to insult you - lighten up, dude
the blog some of us mentioned a week or so back contains every practical build tip by Romero up to his 'exit', sorted into relevant sections
i didn't get those tips by continually 'reminding' people why they're wrong - instead i did something constructive for the thread, on that particular occasion when i read back through the whole thread
