Muller Dynamo
0 Members and 37 Guests are viewing this topic.
Thaelin
   But what Ben isn't tell us all is the view he has too.   :o
Ofcourse, I'll never tell......
thay
   And by the way, thoes are pre-cut pieces. I have no way to do that so have to go with however I can. Cheap too.  ;D
LtBolo
Just a thought about the direction of rotor rotation vs direction of magnetic engagement and even/odd vs odd/even...
Don't underestimate the potential importance of a CCW magnetic flow and/or counter-rotation. We don't really *know* why this worked for RomeroUK. I think I remember some blurb somewhere about it working horizontally and vertically, but not upside down. May mean nothing...perhaps the bearing generated too much friction...but...there could be some kind of unseen vortex behavior that might be depending on the CCW propagation and/or counter-rotation.
The generator coils will generate a field that opposes the rotor field, and as the current comes up in the generator coils, you will get increasing amounts of rotor field cancellation. There have been many discussions about the resulting scalar effects when magnetic fields cancel, and many discussions about rotating magnetic fields. Aspden was very big on such phenomena.
Not suggesting that any of this is important, just suggesting that until you know for sure what is important that you consider coloring inside the lines.
Bruce_TPU
Quote from: neptune on May 19, 2011, 01:25:51 PM
@Bruce-TPU .I ask this question with respect . You say that we get 7 times the WATTAGE using this technique , is that based on irrefutable experimental work , or just theory .
Experimental fact.  You are welcome to read the last few pages of my own thread.
Wind a coil with 7 strands of litz, and the same voltage/amperage is on each strand.  Wire them in series, without diodes, and you have just increased your power x7.  Wire them in parallel (a doable but more "complex" doing) and you have increased your amperage.  OR, do both, as I am with my 10,000 foot of wire coil.
For parallel, keep the negatives all together and the positives all together, then FWBR with smoothing cap (PI filter is even better) then combine with series which is also through FWBR, so that you are connecting DC to DC.
Using diodes for series, with such small coils is unneeded.  With my coil, because of extreme length, and wanting to keep each strand ohm to 38.8 ohms, I have opted for diodes in series.
Wind a litz coil with seven strands, as RomeroUK did, it is easy to experiment with!  Why settle for x1 when  you can have x7.  But then again that is just my simplistic thinking...  ;)
Cheers,
Bruce
neptune
@Bruce . Could you provide a link please?
woopy
Hi Bourne
just demand and you get (Exceptionaly)
Last but not least
yep
good luck at all
Laurent
http://www.youtube.com/watch?v=_TCc6yI2BeA
