Muller Dynamo
energy1234hope
Brilliant Romerouk well done sir. Its experimentors like you that change the world. I am a newbe here from the land down under and been following overunity.com for a few years now as a guest. Joined a couple of days ago. well done again. :D  :D :D :D :D :D :D :D :D :D
i_ron
Quote from: romerouk on May 06, 2011, 07:52:43 PM
well done, first one that shows some progress.
who is next? :)
what is the rotor diameter, thickness?
Thank you, just a cutting from the plastic shop, only 225mm by12.5mm, but was as big as they had.
In scaling up your picture I think your magnets are spaced two magnet diameters apart?  Can you say what the ohms are for a single coil?
What RPM does it turn? Pardon me If you have already said all of this, lol
Rgds Ron
toranarod
Quote from: i_ron on May 06, 2011, 08:55:05 PM
Rgds Ron
The coils are the most in important part. as much information as possible will be better.
the rest I can make all looks very clever because it keep as simple as possible very cleaver Well done.
what are there OHMs ? what are there Henrie's? turns I think you have already stated. and so on?
k4zep
Quote from: romerouk on May 06, 2011, 07:50:29 PM
well, whatever :) call it litz, in UK is called Stranded Enamelled Copper -
Bunched copper conductors each strand individually enamelled
http://wires.co.uk/acatalog/st_wire.html
7 X 0.125MM SOLDERABLE STRAND EN.Cu
Ref: ST01250007-500
Hi Romero
I know two people myself and my good friend in AU that will be experimenting and building as time goes by this device.
Congratulations on your motor/generator.  Sometime can you elaborate on the tuning you do by moving the magnets on the
washers around and setting the distance of coils from rotor magnet?.
Do you look for max RPM (hence minimum drag on rotor) with a fixed load on the generator coil you are "tuning"?  Does this occur with maximum voltage/current output from that particular pair or is there a strong interaction between neighboring coil sets and it is a slow process getting them all at a minimum drag/maximum output condition.  I am super impressed in that I can hear no speed change in the rotor with load applied, or even a slight increase.   It will take a few days or couple weeks to get the Disc and magnets in.  I have the Litz wire, coil forms, electronic parts, etc., that is no problem.  Work space is a major problem but....I will prevail!.  Will be back when I have relevant questions.  Thanks again for your openness, Those videos said so much.!!!!
Ben K4ZEP
hartiberlin
Hi Romero,
many thanks for this wonderful device you have built
and for showing this openly in the public !
Congratulations.
This will really be a candidate for the overunity Prize.
Please don´t change anything on this device and try to rebuild a second unit.
Let me know, if I could come and have a look at it.
Many thanks.
Regards, Stefan.
