Muller Dynamo
0 Members and 302 Guests are viewing this topic.
e2matrix
Hey Mags,  I understand and I didn't realize it had an FET to handle the higher current.  I just take real issue with Radio Shack as I had internal dealings with them and know some things about how they do business and as a result strongly resist buying anything from them.  But they do serve a purpose for some occasions.
   Good luck with the build!  At the rate I'm going it'll probably be a year before I get all the parts together ...
nul-points
Quote from: David70 on May 20, 2011, 09:41:28 AM
The person that scared him reffered to this Muller design only and didn't care about other type of devices he might build in the future, but not this design
...everybody repeat after "3"...  1...  2.... 3....
"I AM SPARTACUS!"    ;)
CLaNZeR
Okay, back home for the weekend and lots of little parcels waiting for me :)
2 sheets of 10mm thick 500mm x 500mm Acrylic for top and bottom stator plates.
1 Sheet of 300mm x 300mm 12mm Polycarbonate for the Rotor.
1 Rotor M10 mounting bolt with 6mm hole.
1 length of 6mm bar for shaft, that will be cut and lathed down to fit bearings
20mm washers
20mm x 10mm rod magnets
M4 threaded brass inserts
M3 threaded brass inserts
2 Pole connector block for each coil
M8 threaded rod
M8 Brass Nuts for threaded rod
2 500g litz wire
47000uf 25v Capacitor
2mm Black and Red cable
Ring Connectors.
Tip42C Transistors
DPDT switches for bottom coils. This will allow me to switch the configuration where needed.
Only thing that did not arrive is the Hall Sensor, but maybe tomorrow.
All other parts such as Rectifier's power supplies etc etc are here already
Will double check measurements in my artwork tonight, create the toolpaths and get cutting tomorrow.
Oh forgot the 3A DC converter that also arrived.
Gonna be a busy weekend !!!
Cheers
Sean.
http://www.overunity.org.uk
toranarod
Quote from: CLaNZeR on May 20, 2011, 02:12:58 PM
20mm washers
M8 threaded rod
2 500g litz wire
Ring Connectors.
Tip42C Transistors
Cheers
Sean.
Helllo CLaNZeR
very nice equipment
look s like you will be demonstrating soon. I am at about the same stage working all the spare time I have to assemble my motor I keep checking to see if we have a replica.
good luck with your build.
My progress so far
CLaNZeR
Quote from: toranarod on May 20, 2011, 03:52:31 PM
My progress so far
Hi toranarod
Loving the Grey and looking good that end, well done mate
Hoping I can get most of it done, will set the coil winder off first thing and get the CNC machine working as they are winding.
Alot of multitasking to do as only got two days and then back off away to work for the week.
Cheers
Sean.
