Muller Dynamo
Bruce_TPU
Quote from: Thaelin on May 22, 2011, 05:27:04 AM
   Maiden motor run with one motor coil pair and one gen coil pair.
  Output is 13.5v after the FWBR. Coils are 3 strands of #30 for
300 turns for about 4.5 ohms total.
Found some D-FW79 SMC sensors that put out high going signal
and operate from 5v to 24v dc. Output voltage depends on input.
Triggers the Fet directly without additional circuit.
Soon as the tach gets here, will be able to give a rpm of it. Will
have all the coils and motor running then. Then I start the bias
part of it. Running right now in repulse mode but will switch when
ready
thay
Hi thay,
Is 13.5 volts open circuit or with a load?
Cheers,
Bruce
k4zep
Quote from: electr0n on May 22, 2011, 04:33:02 AM
Hi, someone mentioned rotor height adjustment earlier, heres what i did.
http://img860.imageshack.us/img860/9404/rrotorheightadj01.jpg
http://img829.imageshack.us/img829/8135/rassembled02.jpg
http://img848.imageshack.us/img848/6374/rassembled01.jpg
A s/steel bolt with the top machined to move the rotor shaft up and down.
Awesome work you guys, some amazing constructing/testing your doing :)
Awesome work indeed!  I'm looking at a mirror of mine except for the height adjustment!!!!  Wow.
Ben K4ZEP
maw2432
Quote from: gyulasun on May 22, 2011, 08:27:11 AM
Hi Bill,
Trying to answer your first question.  Romero used a separate diode bridge for each of his generator coils, ok.  He did not connect the gen coils directly in groups like in series or parallel but he connected all the DC outputs of the individual diode bridges in parallel.  This is surely important once he did so and then this would involve as many AC-DC converters to use as the number gen coils dictate.
Using the many diode bridges surely costs some loss in useful output power because of the forward voltage drops of the diodes and your idea to simplify sounds good of course.  However, if you study the input circuit topology of most AC-DC converters you would find their AC input includes diode bridges... in 99% of the cases I think. It is true that then it would involve only one (common) diode bridge.
Another issue to consider when trying to connect directly in series the generator coils (to use a single AC-DC converter for all of them) is the phase differences between the individual output voltages, it should be studied, otherwise you may have even bigger power loss than the diode bridges otherwise involve.
rgds,  Gyula
Gyula,   thanks for your answer.   So we need the FWBR's because the phase differences of each AC generator coil needs to be considered in capturing all of the AC power.  I guess a common diode bridge would not be able to handle the phase differences.   Is there a phase difference in the coil pairs that Romeo uses? (I believe the top and bottom coil pairs are in a series).
Thaelin
OOPS!   ::)
D-F79W is the right part number........
thay
   They certainly work good too.  Just ran up a single motor coil and output 20.7 volts. That is from a batt at 12.5v.
Quote from: conradelektro on May 22, 2011, 06:20:31 AM
@thay: I could not find the sensors you mentioned, could you please state a source?
Greetings, Conrad
Thaelin
   Bruce:
    Well now its 20.7 but yes with no load yet. Just woke up the neighbors upstairs so have to mellow out a bit. Need to find my car bulb and see what it does with that. 12v  .9a is its norm.
thay
