Muller Dynamo
lanenal
Quote from: romerouk on May 07, 2011, 05:54:05 AM
The square is a bridge rectifier and diodes are making another rectifier in parallel.
I wonder if just two bridge rectifiers doubled together would be the same?
gauschor
Hmmm... ok, I think I understand now, thanks, gyulasun, RomeroUK, Groundloop
romerouk
This one is much easier to build. I tested it with very good results.
lanenal
Quote from: romerouk on May 06, 2011, 12:02:28 PM
The 'helper magnet' is separated from the coil by the thickness of the acrylic (1cm).On the acrylic is glued  a 1mm/20mm washer then the magnet on top.
I am driving in attraction mode. I have started the project in repulsion then tried attraction. I get much better torque in attraction.
Does the attraction mode work this way: the driving coil is switched on when the rotor magnet is approaching and then the driving coil is switched off at the TDC?
Groundloop
@All,
My old Muller motor/dynamo has been collecting dust for 8 years now.
Now I have cleaned the motor and is wiring up the coils. I have
eight 32mm dia x 20mm Neo magnets in the rotor arranged NSNSNSNS.
(Can't make all the magnets the same side out. The magnets are
glued to the rotor.) I have 7 coils pairs. All coils are air core, so
no clogging. I use one coil pair as motor and 6 coil pairs as
dynamo. I have 30000uF 25 Volt capacitors. (Three 10000uF in parallel.)
My Muller is made of Bakelite (paper phenol).
GL.
