Muller Dynamo
hartiberlin
@Konehead:
I think dumping caps into each other just via switches only is not such a good idea, as you loose HALF OF THE ENERGY IN EACH DUMP!
BETTER use IMPEDANCE MATCHING,  so the easiest way would be to use the RIGHT pickup coils.These have to have the right impeance to get the most output power out.
Regards,Stefan.
Tudi
might be complete BS, but here is how i imagine the magnetic field propagation might help this whole thing
http://img607.imageshack.us/img607/6448/therightrpm.jpg
hartiberlin
@Loner
With your 0.8 Volts DC Voltage, are you sure it is not from the magnets deflecting the electron scope trace?
Or do you have a newer scope with an LCD Screen?
hartiberlin
Regarding the 2 Hall sensors Romero used and what Ben just mentioned:
It still puzzles me, why in the world did Romero use 2 Hall sensors and not just one to control the switching of both driver coil pairs?
Normally one Hall sensor should be enough to control this,right?
plengo
Quote from: itsu on May 23, 2011, 07:13:11 AM
Hi all,
Does this statement from Romero (see highlighted part by me) not imply that the motor coils are working in repulsion?
Regards Itsu
I think this is very inline with what Loner said here (http://www.overunity.com/index.php?topic=3842.msg287979#msg287979). If the extra kick of the magnets interaction happens as MIT professor says and Thains has shown in his video, it could mean that Romero does not understand (or may be he does) why he needs the extra trigger at "1 mm" apart because one can not see that extra kick.
IF the extra "magnetic kick" comes at after TDC (which sounds logical) it will be a few millimeters from TDC where the other radial small sensor magnets (that trigger the hall) would trigger the hall too early.
With the extra HALL on the top of the main magnets would be the next best place to position the second hall.
I think things are starting to make more sense as we learn this thing.
Fausto.
