Muller Dynamo
xenomorphlabs
Quote from: gotoluc on May 23, 2011, 12:23:26 PM
My first thought was also, "this is Thane Heins effect"
I know this effect well as I personally work with Thane.
The only way we could take advantage of this effect is if we could somehow get the magnet rotor turning freely as if there was no generator stator core there.
If anyone can solve this one then you will produce OU free energy.
Luc
Something similar to this has been successfully done by Takahachi.
It is so-to-say a Lorentz asymmetrical Regauging.
Tom Bearden explains this in Energy from the Vacuum Part 16 : "Equilibrium, Entropy and Energy defining Moments. (Something TommyLReed should urgently watch too, but he prefers to continually post his antique views here 10 times a day, just to find them deleted an hour later).
Source: http://www.cheniere.org/misc/wankel.htm
e2matrix
Just a reminder on the correct setup for coils with the ferrite rod or other material.  The ferrite needs to go half way through the acrylic. This is per Romerouk.  I was reminded of this when thinking about how to order acrylic.  Depending on your abilities and shop equipment or if you have someone else do this it may be difficult to get a hole only half way through the acrylic as is needed for the sheets that hold the coils.  So as a result it may be better to glue two half thickness sheets together as Romeruk did.  See the pic below that I borrowed from earlier in this thread and added a little detail to the blowup.
neptune
@e2matrix . What you say is important , but as the acrylic plays no part in the working of the machine , as far as we know , it will do no harm to have a hole drilled right through . The important thing is that the ferrite only fits half way through . In other words , maintain a gap between the ferrite and the steel washer .
bolt
Quote from: TommeyLReed on May 23, 2011, 12:26:57 PM
The problem is there is no free lunch, you cant get more energy out then what you put in this Muller motor. Why can't anyone see this?
Tommey, I am very surprised at you to take this stance. From many others yes its understandable but i seen your work and i know you been making stuff for years. What has happened to you? Have the goons been to your ranch and paid you off to stop working on OU?  Have you not seen Ismael has a MEG on electric car with a COP of 2.7 tested by DOE and DOT government engineers? Have you not seen the German HHO Genset Looped? Now you see RomeoUK muller. Not even to mention the TPU, VTA, Kapandze and 100 other devices. For me I not at all surprised you will see more with any luck soon. I seen looped RV motors 4 years ago over skype.
You know its damn funny to read back thru old posts and see the "flat world" people and there claims of "ITS IMPOSSIBLE" and "you can not loop because it breaks the law of physics?" Really and who's LAW are we talking about?
FYI all devices have losses but by converting the losses to gains with a COP>2 you can loop. It takes a high level of consciousness  to see how to tune the system. Out of all the replications on here only a couple will succeed.
woopy
Hi Gyula and Stephan
So i made some testing with a load on the machine
For the load i hooked a small DC 12 volts motor with  a propeller. between the cap and the small motor i put an amperemeter.
So after the first test, i got a very low efficiency , Only about 25 %. And than i tried to remove all biasing magnets to redo everything from the beginning. And by doing this i noticed that i fergot to reconnect the 6 coils set  to the first coil set ,when i made the voltage test from yesterday.  Arrgghhh.
So i was more happy by thinking that when i reconnect the 6 other sets it will be really interesting.
But the efficiency did not go up. only about 30 %. (testing without biaising magnets)
I use FWBR on each coil set, and those FWBR are connected in parall to the cap and the load. The diodes are BYV 26 d.
I checked all the coils under load and all of them are producing a steady sine wave (pix 1).
I am investigating why i get 0.52 watt on one coil and why i do not get 7 time those 0.52watt when all the coils sets are connected??
Is there a problem with the FWBR ?  Any idea ?, do i have to double the FWBR ?
Any other replicator with such problem?.
For info ,the trace of the one coil set after the bridge (pix 2) and the trace of all the coil after the bridge (no load)
Just before making this post i could get batter timing with the Hall under load. The timing is really sensitive.
OK always waiting for my litze.
Good luck at all
Laurent
