Muller Dynamo
0 Members and 82 Guests are viewing this topic.
hoptoad
Quote from: i_ron on May 27, 2011, 10:38:53 AM
Hi HT,
yup, the somaloy coil is a heel design, the core is 24.9 mm long, the winding is 12 mm long. There is a 12 mm (approx) plain portion of PVC that I was going to use for three tapped holes to mount the finished coil if the test was a success.
Yes I believe the heel design works regardless of the core material.
In this case, with the magnet on a 2 mm plastic spacer, it does improve the output, whereas separated by the stator plate thickness,as R suggested, doesn't work.
Kind regards
Ron
Thanks for the feedback Ron.
Cheers and KneeDeep
wopwops
Off Topic: Mods, please delete if necessary
Dr. Steven E. Jones demonstrates 8x overunity circuit
http://pesn.com/2011/05/27/9501835_Steven_E_Jones_demonstrates_overunity_circuit/
Professor Jones has developed a variation of the 'Joule Thief' circuit and has shown that its output is eight times greater than the input as measured by a state-of-the-art oscilloscope. He is open sourcing his solid state design to help speed its development and implementation, as well as to answer the scientific question of where the energy is coming from.
Pirate88179
Quote from: wopwops on May 27, 2011, 11:20:00 PM
For those interested, that is being discussed over on the JT topic.  There are some problems with Sterling's article as have been pointed out over there. That will keep this discussion on topic over here.
PS  Moderator feel free to remove this post as well.
toranarod
Quote from: hyiq on May 27, 2011, 09:58:50 PM
It is easy to pick the serious from the non serious.
ZeroFossilFuel has, and is doing an excellent job. I have a few different projects on the go, but think RomeroUK's work is superb and he is genuine all the way. Anyone that doubts RomeroUK's Work, has not done their home work as we know. I plan to replicate RomeroUK's work after some of my current projects are out of the way.
Everyone is doing a good job. Remember to keep the same principals and ideas, keep it in-line with RomeroUK's work to get the best result. Get it working first. Then play around with it to try to improve it. The Wire is the one place I see most are not inline. Multipal Filar Wire (Litz Wire) is important. Each Filar in Litz Wire has unique properties that a single Filar Wire does not. Make your own Litz Wire if needed.
Test: Take a spool of Litz Wire, Measure one Filars DC Resistance, Then Measure two Filars, together, and so on. See what you get. The DC Resistance will drop by half, for each Filar that is added. Plus with a single Filar there are more problems with self inductance between the windings and so on.
Thumbs up from me everyone. Dont pay any attention to the nae sayers. They dont warrant any time and resources. Everyone is doing an excellent job.
Keep up the good work for the good Fight!
All the Best
  Chris
I fully support the above statement.
I was hoping that we could start post results by now. any results are all important.
If you don,t get OU that doesn't matter we all need feed back to guide us in the right direction.
I would like to read what we are discovering about the Romero replication Good or bad. all that matters is the truth be found.
I will post a full report on what I have documented so far.  based on my motor. as stated we have not all been able or willing to replicate to the letter.
Rod
JouleSeeker
Hi, this is Prof Steven Jones.  Glad to be here.
  I actually began a thread on this "reverse-JT" circuit here at OU on May 20th:
http://www.overunity.com/index.php?topic=10773.msg287594#msg287594
I invite replications and further testing!!
Also, I have asked Sterling Allan to make a few corrections to his article -- thanks Pirate for your input.
--Steven J
Moderator:  feel free to delete this post if necessary; just a follow-up to a comment on this thread.
