Muller Dynamo
0 Members and 46 Guests are viewing this topic.
nul-points
Quote from: JouleSeeker on May 28, 2011, 09:38:35 AM
Hi, this is Prof Steven Jones.  Glad to be here.
  I actually began a thread on this "reverse-JT" circuit here at OU on May 20th:
http://www.overunity.com/index.php?topic=10773.msg287594#msg287594
I invite replications and further testing!!
Also, I have asked Sterling Allan to make a few corrections to his article -- thanks Pirate for your input.
--Steven J
Moderator:  feel free to delete this post if necessary; just a follow-up to a comment on this thread.
hi Prof
not quite so off-topic, now that Lidmotor has used a dual JT type circuit to drive his Muller rep!
maybe you could advise him if he could adapt your circuit to drive his rig instead - not sure of the resonant frequency implications tho'
would be an interesting development if BOTH motor AND generator sections were OU!
all the best
np
http://docsfreelunch.blogspot.com
JouleSeeker
Quote from: nul-points on May 28, 2011, 09:56:53 AM
hi Prof
all the best
np
Excellent point, nul-pts.  I appreciate your encouragement also.  Not everyone likes to have a Physics Prof. jumping into this research (evidently).   I have been following the work by Lidmotor (and LaserSaber and others) with great interest.
I should add also that my colleague and I are now building a replication of the Romero/Muller device.  I'm very interested in learning about these devices -- and in making careful measurements of input Power and output Power for them.
  Finally, I would like to determine just where the energy comes from -- I do not think that the laws of physics are being violated here, but rather, that there is an "anomalous" source of incoming energy, a source that needs to be identified.
(PS -- my bias, after having taught quantum mechanics for many years, is that this energy source is NOT zero-point energy {ZPE} from atoms themselves.  I have a few ideas relating to theory, but I feel that experimental verification needs to precede theoretical stuff.)
lumen
Speaking of LaserSaber, He was really on top of this early on and now he seems to have went silent!
I hope everything is ok.
synchro1
@ClaNZeR,
I don't know anything more about the video, but the effect is more important. Toranarod reprorts a 70% gain in efficiency with the help of his core magnets and washers. Now follow me on this: If coil core magnts increase gain is there possible increased gain from increased magnet strength? The ansewer is yes.
Imagine a coil core with a snug fitting diametricly magnatized neo tube inside, mounted over a  N/S magnet rotor. When the north pole passes under the core magnet, the rotor magnet bends the field from the attracting side of the core magnet, by pulling it down through the wire coil wraps to generate current. When it passes, the field retracts back through the wraps and generates another current. The same goes for the opposite rotor pole magnet and the other field from the diametric neo coil core. This is coupled with repulsive field compression. The core fields see saw this way, back and forth through the copper wire wraps, and REVERSE Lenz effect at the same time by propelling the rotor with a Hatem effect, while remaining neutral along the sheer plane. This approach increases output by double and triple amounts not just fractionaly. This charging effect involves no vibration.
Tudi
what about woopy being silent, he had an almost colmpelte rig and now he is also gone ? Most of the people who were capable of building such a device went silent since a while. Maybe it's just the incomming summer.
Joulseeker, i'm really excited about sucha simple circuit of yours. Will try to visit a hardware store to see what i can do to confirm or not your results. Have really small practical knowledge, but that is why i'm here :) ( failed physics class 3 years in a row xD )
