Muller Dynamo
Arthurs
Hi romerouk
Have two questions:
1) Why is the 8 magnets- 9 coil, In accordance with the muller generator structure, seems 9 magnets- 8 coil More reasonable?
2) Core diameter of the coil you use 6mm, Diameter of the core diameter and the magnet seems rather, the effect will be even better?
I'm ready to replicate, The above issues should I choose?
Thank you for your answer
romerouk
magnets for hall sensors
toranarod
Quote from: romerouk on May 07, 2011, 09:14:27 AM
2 hall sensors. I will take some closer pictures to see them.The side of the rotor has small magnets with south pointing out.
what is the size of the trigger magnets as that determines the pulse width is that a correct assumption.
thank you for your attention I am documenting every peace of info I can get from this blog.
have made the disc and installing the magnets at the moment.
toranarod
Quote from: romerouk on May 07, 2011, 09:17:37 AM
you are a legend. you should be remembered with Tesla.
toranarod
how many trigger around the disc ? I assume 8
