Muller Dynamo
0 Members and 171 Guests are viewing this topic.
gauschor
@Clanzer: wow, this is helluva clean and professional setup you posted here. Hats off  :)
REDCAR1957
Quote from: CLaNZeR on May 28, 2011, 03:13:04 PM
Quick update as been a busy day and pictures attached.
Bottom Base all wired up.
Top Plate all cut out and just need to wire up.
Rotor cutout and magnet press fitted in at exactly 11mm deep. Small side magnets pressed in.
Picture of the rotor layed on the base for comparision.
Off to lathe down the axle now and get the wiring finished for the top plate.
Cheers
Sean.
CLaNZeR
Awesome design setup ;D
I am looking forward to seeing the results from
your EXCELLENT work ;)
RC
maw2432
Cheers
Sean.
CLaNZeR
Very nice design and yes Awesome setup - one of your best!
Could you take some time and share your bearing setup for the Rotor?
Many replicators are having some trouble in this area.
toranarod
CLaNZeR
Very nice looking forward to you results.
here is some of m work
The magnets fitted to the cores.
Current specifications
The motor has one drive coil as seen in photo below.
8 generator coils paired. All fitted top and bottom with 10 x 10 neo magnets.
Each pair outputs 50 volts .at 1500 RPM
Drive coil consumes 60 mill amps RMS on 24 volt supply on a 1.2 mill sec drive pulse per magnet switch time.
all Mag ten
green wave form is generator after bridge rectifier
Yellow drive pulse
Tudi
thanks all for the updates. For a sec i thought something happened.
@toranarod : your generator seems like a common generator. I mean a really common one. Almost perfect sine wave. No spikes, no back EMF elimination... :(
