Muller Dynamo
0 Members and 81 Guests are viewing this topic.
WilbyInebriated
to whom it may concern: User2718218 is the former ou.com member 'milehigh'.
e2matrix
Quote from: WilbyInebriated on May 28, 2011, 08:10:20 PM
Sounds about right since Milehigh seems to only see conventional physics and EE theory and anything outside of that realm is firmly put down as impossible.
CLaNZeR
Quote from: conradelektro on May 28, 2011, 07:16:31 PM
When looking at the photos in your latest post I wounder why the bottom bearing does not slip of the bottom plate when the rotor is pressing down on it (via the shaft which is lathed down to 3 mm)?
I understand that the bearing fits tightly into the 6 mm hole, but when vibrations start it eventually could fall off the plate nevertheless?
Hi Conrad
The bearings will not go anywhere as they are flange bearings.
So the diameter of the bearing shell is 6mm but the top of the bearing casing is about 8mm diameter.
Bottom bearing has flange facing towards shaft and top bearing also has flange facing towards shaft.
So no up and down movement at all, I have used these for many years on many rigs and all good :)
Cheers
Sean.
http://www.overunity.org.uk
resonanceman
Quote from: LtBolo on May 28, 2011, 02:54:50 PM
Why are they important? They both point to high frequency response, much higher frequency than would make sense for something operating at a couple of hundred hertz.
Why high frequency?
I can think of a few things that have nothing to do with pulse motors or axial generators. Romero himself made the comment that there was more here than just a generator. I think that until you answer the question of why high frequency response is critical, you will miss the real energy source.
Just food for thought.
LtBolo
I agree that the modified bridge is about the real energy that made it OU.
To me it points to using the energy of the BEMF pulses.
In the Joule thief thread it is suggested  that bridges be modified to collect energy better......they do it a little different.......by adding fast diodes in series  with the inputs to thbe wothe bridge.......It seems that the standard bridges are just not fast enough to deal with the speed of the spikes
It might be an idea to just build your own bridges with ultra fast diodes.
gary
Magluvin
Dang. Clanzer.  It just doesnt get any better than that. ;]
I like Zero Fossil Fuels way of doing vids. Just open and in the vids himself.  Maybe this is the way to go.  And let all your family and friends and many YTers know who that person is. This way more people, hopefully in some cases, would question what happened.  :o  Would it be less likely to get visits this way?
When we are all "invisible"  hardly anyone knows you, the person presenting the vid, at all, making it easier to cover up.
Im just happy everyone is around an no visits.  ;]
Super work by all of you guys.  Its a wonderful thing. ;]
Mags
