Muller Dynamo
0 Members and 80 Guests are viewing this topic.
neptune
@toranarod . Looking at Romero`s videos we do not see magnets on top of the drive coils ,or inside the drive coils .
i_ron
Quote from: hartiberlin on May 28, 2011, 06:58:18 PM
snip
Good luck.
Regards, Stefan.
Stefan,
There is a readability problem when people post over size photos.
Page 149, for example is a pain as you have to scroll twice the page width to read all of the posts.
Would it be possible to automatically not accept photos over 800 X 600?
or at least post a notice that photos should be 800 x 600 or under?
Thanks,
Ron
i_ron
Quote from: yssuraxu_697 on May 29, 2011, 09:57:00 AM
snip
With i_ron's latest developments with ultra high output coils one way would be substituting neos
with non conducting ferrite magnets and eliminate those losses while still having reasonable output.
Thanks for the acknowledgement!
Just a further report on that... I wound a second one with Litz wire (monitor salvage) and the output was not as good, only 4.68 watts.
However the two coils together, in series, produce 15 watts. (1.5 mm gap)
Nu math, 5 + 5 = 15.... go figure, lol
But in reply to ZF's 1/4" gap suggestion, at 1/4" the out put (for one coil) was 1/2 a watt.  So it might 'skate' on by but the output will be seriously compromised.
edit:
However with high output coils, this allows me to open up the gap (3mm) use a 100 ohm (from 20 ohm) load resistor and, discounting the RV drive motor draw for a moment, realize in/out numbers close to 1:1.
Ron
synchro1
Quote from: neptune on May 29, 2011, 10:36:27 AM
Toranarod has demonstrated that coil core magnets increase output over the Muller design. Orthodox criticisem of innovative improvement has questionable worth.
hartiberlin
@toranarod
are you running your motor just with drive coils and no pickup coils ?
If not, do you also have scopeshots of your pickup coils WITH and WITHOUT the
cap after the bridge and a load resistor across them ?
Many thanks.
P.S: A video showing your motor would be also good to see...
Regards, Stefan.
