Muller Dynamo
0 Members and 44 Guests are viewing this topic.
hyiq
Quote from: hyiq on May 29, 2011, 07:54:22 PM
BEAUTIFUL Work!!
If anyone in interested, I have built a few simple Excel Spreadsheets to help with documentation. Maybe if those building Motors want to use the SpreadSheets and repost with data?
infringer
Clanzer is almost there!
http://www.youtube.com/watch?v=mcL-EeIeG6s
Talk about beautiful work this guy has got a knack for this stuff I know when he sets up his custom milling I will be ordering from him a time or two.
Great work Clanzer! The whole community really benefits from your hard work and I cannot say myself how many times you have made fine builds to try to prove or disprove a technology. Dunno how else to do it so I will say it.
THANK YOU!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
duff
Clanzer,
It will be interesting to see how the rotor magnets spinning at 2700+ RPMs affect the wiring you have in the channels  parallel to the rotating magnets.
hoptoad
Quote from: i_ron on May 29, 2011, 10:55:52 AM
Thanks for the acknowledgement!
Just a further report on that... I wound a second one with Litz wire (monitor salvage) and the output was not as good, only 4.68 watts.
However the two coils together, in series, produce 15 watts. (1.5 mm gap)
Nu math, 5 + 5 = 15.... go figure, lol
But in reply to ZF's 1/4" gap suggestion, at 1/4" the out put (for one coil) was 1/2 a watt.  So it might 'skate' on by but the output will be seriously compromised.
edit:
However with high output coils, this allows me to open up the gap (3mm) use a 100 ohm (from 20 ohm) load resistor and, discounting the RV drive motor draw for a moment, realize in/out numbers close to 1:1.
Ron
My highlight to quote above.
As always, Ron, it's good to see your builds and read your results.
Cheers
infringer
Quote from: duff on May 29, 2011, 09:48:59 PM
Clanzer,
Likely little to no effect will be observed beyond what romeroUK would have observed I presume due to the thickness of his stator plates top and bottom I believe this would be a non issue if you observe romerouk's thickness vs clanzers he even went as far as to etch the washers down far enough to where they were in spec with the distance of romerouk's device so I believe this is a fairly concrete replication and if it does not work there are adjustments and a few additional things to try but beyond that I would personally consider it near debunked.
-infringer-
