Muller Dynamo
scratchrobot
Quote from: kEhYo77 on May 30, 2011, 03:55:01 AM
Hi. I'm on this as well, I'm just a little short of money for the components so it goes slow. I would like to put some thoughts on the matter.
From what I know RomeroUK had been working for a while with coil shorting and in my opinion it is somehow incorporated in his design.
From recent disclosure of Ismael Aviso coil shorting technique as the main overunity factor I think it must be true and if not, some of You builders must try this.
So the generator coils should be 'open circuits' until a magnet reaches TDC, then you short the coil for a fraction of second and you open it again and then collect BEMF.  The coils should be wound bifilar, in series (Tesla) because such winding has much bigger energy capacity in comparison to a standard coil. In coil shorting it will be far superior as it is in a sense a coilpacitor of sorts. So for those of you using Litz wire it is just a matter of doing some soldering and proper timing.
I think Romero might be using those tiny magnets for timing of this process...
http://www.youtube.com/watch?v=mEaY17NeK_I
Many theories about how it works but I think this video shows the effect we need to create a selfrunner.
Any body knows what circuit he used in this video? I don't see shortening the coil for a fraction of a second but just shortening the coil continuously and the speed increases!
@CLaNZeR, very nice build, I can't wait to see it run. Maybe you know what circuit Romerouk used in the video?
Good to see so many people replicating.
scratchrobot
The Observer
Nexus,
Thank you for your post.
You say your friend says...
QuoteIf this works I suspect that it's not 'free' energy....
I suspect that it's working from the earth's motion (Coriolis effect) somehow.
Meaning that if lots of people made these things, it would start to slow the earth's rotation.
Not sure I'd want to be responsible for that!
Someone should do the physics.
You can tell him that there is no such thing as an Overunity Device.
There are however, Unrecognized Sources of Energy.. that I term as USEs.
In the case of the Muller Dynamo,
the Unrecognized Source of Energy is that of Unpaired Electrons Present in Ferro Magnetic materials.
These Electrons Move without being hooked up to a voltage potential that was "paid for."
It turns out that Soft  FerroMagnetic Materials can amplify the magnetic field of a coil by 1000 to 1,000,000 times.
This is without using any extra current !
This parameter is called Magnetic Permeability.
The reason that a FerroMagentic Material can do this is because it is composed of freely rotating Atomic sized Magnetic Dipoles.
These dipoles randomly orient themselves in the absence of an external magnetic field.
However, when in the presence of an external field, THEY LINE UP AND ADD TO THE EXTERNAL FIELD.
--- THUS AMPLIFYING THE EXTERNAL FIELD. --- (effectively 1000's of times amplification !!!!!)
...see diagram below...
Forrmula for a Magnetic Field inside a Coil.
                                                            B = (μ0 * μr * N * i) / l    -->    B =   Î¼r * (μ0 * N * i) / l
                                                    - μ0, N, i and L are constants for any given coil with a constant current.
                                                   - μr is the Magnetic Permeability of the material within the solenoid.
                                                   - (99.9 % of all substances have a  μr ~ 1,      Ferros have a μr  ~ 500 to 1 Million)
There is no way this motor would work if it were composed of just coils to produce the magnetic fields.
You need the FREE UNPAIRED ELECTRON SPIN present in the Magnets and Cores for this to work.
If your friend wants to contemplate the earth slowing down,
I would ask him to consider the amount of work tides do on the earth... without the moon moving closer or the earth slowing down !
Best Regards,
                  The Observer
Magluvin
I cant agree with this statement from the so called EE.
"If this works I suspect that it's not 'free' energy.... I suspect that it's working from the earth's motion (Coriolis effect) somehow. Meaning that if lots of people made these things, it would start to slow the earth's rotation. Not sure I'd want to be responsible for that! Someone should do the physics.
{snip}.
Romero had shown that it works vetical, horizontal, and swinging on a string, this way and that way.  Its funny how some come to seemingly solid conclusions at a glance.
I have faith in Prof  here to find some truth in it all.  ;]
Mags
JouleSeeker
Quote from: Magluvin on May 30, 2011, 01:11:54 PM
{snip}.
Mags
Thanks, Mags -- we're in this together.
I agree it's not the Coriolis effect involved here. (!)
A brief comment on a possible source of anomalous energy that we know very little about (except for its existence)  -- from a NASA website:
"What Is Dark Energy?
More is unknown than is known. We know how much dark energy there is because we know how it affects the Universe's expansion. Other than that, it is a complete mystery. But it is an important mystery. It turns out that roughly 70% of the Universe is dark energy.
Dark matter makes up about 25%. The rest - everything on Earth, everything ever observed with all of our instruments, all normal matter - adds up to less than 5% of the Universe. Come to think of it, maybe it shouldn't be called "normal" matter at all, since it is such a small fraction of the Universe. "...
"Another explanation for dark energy is that it is a new kind of dynamical energy fluid or field, something that fills all of space but something whose effect on the expansion of the Universe is the opposite of that of matter and normal energy. Some theorists have named this "quintessence," after the fifth element of the Greek philosophers. But, if quintessence is the answer, we still don't know what it is like, what it interacts with, or why it exists. So the mystery continues. "
Read more:  http://science.nasa.gov/astrophysics/focus-areas/what-is-dark-energy/
Gosh, is it possible there is a source of energy we don't already know about?  ;)
Pirate88179
What is up with that so called EE claiming it is not FREE energy when it runs closed loop?  Hello?  I guess it might be a semantics issue but really, no power in, power out....sounds like free energy to me.  How do we know there is power out?  Because it is running!!!
Some of these so-called experts really scare me.
