Muller Dynamo
0 Members and 36 Guests are viewing this topic.
lanenal
Quote from: gotoluc on May 07, 2011, 09:29:49 AM
Hello romerouk and all
My congratulations romerouk on your dedication and hard work towards the research of free energy solutions.
I have a concern on your previous video to the self runner.
Below are frames taken from your video before and after the bulb is turned on. I can see that the amp meter doesn't change however, there is a large drop in your Battery voltage every time the bulb is turned on. Then when the bulb is turned off the battery voltage recovers from the load.
Can you explain. Sorry if this has been explained before.
Thank you for sharing your excellent research.
Luc
Yeah, this one is ansswered already, see below:
I had few questions from the 'replicators' here about voltage on the battery going down when the load is on.
The reason for that is that from the output bridge rectifier I am using one diode to send power back to the battery to keep it charged.When the 20watt bulb is connected the power going back to the battery is reduced resulting that slight voltage drop.
This setup was built for about 25watt load, if the load is increased then all setup must be changed.
The gap from the coils to the rotor must be changed and some other things ...
Basically from my understanding, the 20w bulb is too heavy a load for the system...if it were a 5w bulb, you should see no voltage drop at all.
lanenal
Quote from: hartiberlin on May 07, 2011, 09:36:06 AM
Hi Romero,
what is the spacing from the 2 driver coil pairs to the
pickup coil pairs ?
What is the interleaving there ?
Do you have the 2 driving coil pairs next to each other
or are they like:
1 driver coilpair,
4 pickup coil pairs
1 driver coilpair,
3 pickup coil pairs
Do you have an magnet polarity measurement device ?
Can you exactly say, if all the magnets inside the rotor
pointing up, when you have the device standing on your table,
are north or are all magnets inside the rotor pointing up
have south pole ?
It might be interesting to know this.
Maybe if you turn around your device on the
head (180 degrees turn),
will it still selfrun ?
So this could be an easy test to see, if your local
earth magnet field has anything to do with it and the devices direction
to it.
Many thanks.
Regards, Stefan.
I also asked about the coil spacing before...
Note that this is actually different from the original Muller device: on the Muller device, ALL coils serve as driving coil AND power generation coil, but in turn. RomeroUK has made this much simpler by using dedecated driving coils and generation coils. This is a great simplification.
gotoluc
Quote from: lanenal on May 07, 2011, 09:36:12 AM
So Romero has gone from a large voltage drop with battery connected when the bulb is on to a self runner using the same load with no battery connected?
These are amazing improvements!!!
@Romero, can you please redo a continuous sound video with your Muller on a glass (away from the legs) showing it running the load with no battery. Please do a view under the glass and all around as it is running.
Thanks for sharing and your time.
Luc
xenomorphlabs
@ Romero:
Thanks for the links, i have not been aware of the youtube replicators concerning the Kromrey device.
Does your Muller device also run cold at some points? Have you tested that?
For anyone interested in more information on this, Energy from the Vacuum Part 10 shows Bedini running a Kromrey Converter and explaining the principle.
romerouk
Hi Romero,
pickup coil pairs ?
or are they like:
1 driver coilpair,
4 pickup coil pairs
1 driver coilpair,
3 pickup coil pairs
have south pole ?
to it.
Many thanks.
Regards, Stefan.
pickup coil pairs ?
I don't understand this question.
The 2 driver coils are not next to each other, one coil is on one side and the other exactly on the other side.
All magnets on the rotor are all pointing same direction, as you look at the device all magnets are with South up. I have never tried to run it upside down because of the dirving circuits but I will try it having it on one side.
I don't have a  magnet polarity measurement device.
