Muller Dynamo
dutchy1966
Quote from: hartiberlin on May 07, 2011, 10:36:08 AM
Hmm,
now I don´t understand your answer.
You say you have 9 coil pairs.
Which coil pairs are the 2 drivers and which coil pairs
are the pickup coil pairs ?
Just look at the pictures he supplied you can easily see it on there:
driving coil 1 --- 4x generator coils --- driver coil 2 --- 3x generator coil
Hope that helps.
regards
Dutchy
romerouk
Parts left from my previous attempts. I might be able to use some towards the new build.
I am thinking to double the number of coils and magnets too. 3 driving coils will be better.
i_ron
Quote from: gotoluc on May 07, 2011, 10:09:28 AM
So Romero has gone from a large voltage drop with battery connected when the bulb is on to a self runner using the same load with no battery connected?
These are amazing improvements!!!
@Romero, can you please redo a continuous sound video with your Muller on a glass (away from the legs) showing it running the load with no battery. Please do a view under the glass and all around as it is running.
Thanks for sharing and your time.
Luc
Good to see you here Gotoluc, I have followed romero's work for a long time and can tell you straight out there is no hanky panky going on. You and Harti need to read the thread and just replicate, that is all he asks.
Lets all respect romero's privacy and patience.
Regards, Ron
Arthurs
Hi romerouk
Have two questions:
1) Why is the 8 magnets- 9 coil, In accordance with the muller generator structure, seems 9 magnets- 8 coil More reasonable?
2) Core diameter of the coil you use 6mm, Diameter of the core diameter and the magnet seems rather, the effect will be even better?
I'm ready to replicate, The above issues should I choose?
Thank you for your answer
romerouk
First picture shows 2 motors that are almost OU when comming from factory.They come with Muller arangements inside already.I have left info about them but looks that it was missed.
This is probably the easiest way for people to try Muller's config.You don't get a lot out but more than in.I have tested it with another normal dc motor to drive the shaft.Come on people, this one is cheap, search on ebay for it.You need to redo the windings again to have sections of 2 coils next to each other forming one set, coil up and coil down from my larger device.I used 0.3mm single wire.
Second pic shows more parts that are going to be used to the next device.
