Muller Dynamo
0 Members and 85 Guests are viewing this topic.
tysb3
REDCAR1957
Quote from: woopy on June 02, 2011, 06:39:10 PM
Hi all
2 other cents wayting for Rod's (ToranaroD) news  and Lasersaber and Penno and others replicators
good luck at all
Laurent
http://www.youtube.com/watch?v=3SdnN8su3Yc
Woopy
did you use single strand wire?\
why not use litz wire as Romero did? 7 strands .125mm
hyiq
Quote from: konehead on June 01, 2011, 01:21:18 PM
Anyways, with coil-shorting subject, you sould use BIDIRECTIONAL mosfets, since these switch AC (thanks Gyuala) ....simply hook the gate and source together with two mosfets, and the swtiching occurs between drain #1 and drain #2.
If you dont do this, you will catach only half the possible energy when coil shorting.
Also your mosfets must be high-amperage, very low resistance type or the extra resistance kills everything - using a solid state relay, or a SCR, are a couple of swtiches that will not work with coil-shorting since their resistance is too high...put mosfets in paralell to lower resistance even more if you want (Ismael trick)
this is why using a reed switch to do coil shoritng works so easy - they will swtihc AC, and they have very low resistance....but they also will blow up very easily too, so stick with bidirectional mosfets.
Also important thing, is to not put the extra-power/voltafge you make with coil shorting "directly" into the load...this will also kill all the big gains in power/voltage -
Hi KoneHead,
Please could you draw up a simple schematic with your above idea?
Thanks
All the best
  Chris
scratchrobot
Maybe device works on Cromrey converter principle I see some similareties like the double coil, multiple coils in parralel (litz wire), magnets on both side of coils and ofcorse the speed increase under load.
I know there are some very clever people around here so maybe someone can explain why the cromrey device speed up under load?
Regards,
scratchrobot
chessnyt
Quote from: REDCAR1957 on June 02, 2011, 09:50:07 PM
Woopy
It just baffles me how people expect to get the same results as RomeroUK when they are not even using the same parts.  I'm getting ready to replicate a 1965 Ford Mustang.  Does anybody know where I can purchase Chevy parts for my Ford replication?  ::)
