Muller Dynamo
0 Members and 85 Guests are viewing this topic.
David70
Info from a document:
'' What actually happens ?????. If your motor is operating within the "realm of disbelief", as it likely will (LOL), you will notice something very strange!!.
You may notice the following:
When R1 was turned on, the motor slowed a little bit, When R2 was turned on the motor may have slowed a little bit again, but not as much when R1 was turned on. Same when you turned R3 on, but when you turned R4 on, there appeared to be no change in motor speed at all. You continue and find that when you turned R5 on there was still no change, but when you turned R6 on, the motor seemed to speed up again. Same with 8, 9 and 10. It's almost at the speed when you started. Then to your greatest surprise, you turn the short circuit on, and the motor goes to full speed as if there were no load at all.''
Check the folowing link and read it carefully, it is exactly what Romero sugested with his speed up under load. Some of the energy goes back to the system and maintain the speed and the difference we can use.That difference multiplied by 7 coil pairs should be what we are all looking for. As he was saying, must match the load with the coils and the speed. I tried it with one coil and after many attempts and hours spent I managed to replicate the effect.I am using NSNS config with a coil similar with what he shown, 850 turns.
I have no cable to download from the phone to the computer and post pictures here.
Read the info completely, we have answers to many questions.
http://www.totallyamped.net/adams/#top
toranarod
Quote from: konehead on June 03, 2011, 02:08:03 AM
Here is bidirectional mosfet coil-shorting circuit using halleffects.
and you should use a 4421 driver (it will be normally OFF-switches ON from the hall effect)  instead of the 4422 shown in circuit and it will work fine as is.
Not shown is a "two-stage" output circuit...that high-bypass series AC cap will eliminate motor lugging, but there is balance in the uf value you want -  as too low of uf and not much power gets through to fill cap very fast and too high of uf and you can get lugging of motor but cap zaps up very fast so there is need to find balance.
To do a two-stage output circuit, "double" all this up and use a 4422 and a 4421 both triggered by same halleffect at same time. the 4421 will be normally OFF switches ON and the 4422 will be normally OFF swtiches ON...
so use the 4421 mosfet circuit to dump "collector" cap to load, and use the 4422 mosfet circuit  o fill collector cap while mosfets are "normally ON", and disconnect  cap from coils being shorted when collector-cap hits the load, as the 4422 circuit switches OFF from a common halleffect tha both drivers share (and the 4421 switches ON at same time dumnping cap to load)
use any size mosfets you want for whatever system you have going, and you can put some in paralell to reduce resistance if you want to do that..
you dont necessarily need to be charging a battery, that could be any load there -  and also you might not need or want that high bypass filter cap -  but if you do use it, play around with the uf values of it for whatever you are doing.
you wont need the bidirectional-style mosfets, and you can use single mosfets instead for the two stage output circuit, unless you decide to cut the coils from the collector cap during collector cap discharge on the AC side of the bridge for some reason.
mabye throw in a bunch of opto-isolatorrs too, (more advanced) so you can use one common power source for all the drivers and mosfets and hall effects....
if nothing else, this circuit shows how to hook up bidirecitonal mosfets, with a driver too, in order to short coils and a fwbr is there too, that fills DC cap up from the coil shorting...so that is the basics....
Thanks konehead very helpful. In the last 24 hours I have been frantically constructing all the necessary electronics.
I Haven t even stopped to answer email.
I will post any results good or bad.
cheers
hhobrian
Quote from: plengo on June 02, 2011, 07:35:54 PM
Just because we don't understand or current science explains to the level of our experiences does not mean it is not possible. Lenz law is just an explanation of physical realities limited by our experiments and understandings of the real thing. They
I agree, always thought should be called Lenz effect rather then Lenz law
tysb3
Quote from: firlight on June 03, 2011, 04:52:40 AM
This is my first post here ,This post about the Adams motor is spot on,you really don`t need magnets on the back of the generator ,its cheaper to extend te core,hold a chunk of iron or a length of ferrite rod on the backend and check the output with a scope as you do so.
Regards Dave  :)
yes, I think so.
starcruiser
I would not look to test with a resistive load on the generator output but use the capacitor and tune for output using a High Z meter. IMO, this is a tuned (tank) circuit and the DC-DC converter is probably a hi Z device that has minimal impact on the collection circuit. Just my .02
Similar to a rotoverter in some ways.
Regards,
Carl
