Muller Dynamo
skycollection
Sewing Bobbins...! in my oppinion this coils with many thin wires does not work and is a waste of time, if someone is building these KIND OF COILS, do not waste your time and money, NOT WORKING ...!
bourne
Quote from: skycollection on June 03, 2011, 07:57:58 PM
@skycollection are you saying that having plastic between the core material and the wire will not work?
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
resonanceman
Quote from: konehead on June 03, 2011, 01:36:54 PM
Maybe part of the deal with the goons was to not tell everything, and leave a bit out....who knows... but  sure would be nice if those those magnets behind the generator-coil cores do something dramatic in somebody's testing soon.
If Romero did make a deal it would be for ALL his knowledge of his motor.....and I am sure it would be dependant on NEVER telling anyone anything about it for the rest of his life.........
Just a few thoughts about the  magnets on the coils.
We know that Romono expermented with a magnicoaster
The basic configuration is very similar to a magnicoaster..... except the input comes from rotor motion rather than a second set of coils
I am sure he would  have used his knowledge of it as he tuned  his motor
I have not watched all the videos.......is everyone adjusting the magnets with washers ?
In my opinion it will not work without the washers.
I would say that a washer just a little bigger than the magnet would act kind of like a diffuser creating  a softer wider magnetic field
I think the most important function of the washer is based in the way iron responds to a magnetic field.
If  you place a thin core on a magnet  the polarity  will stay the same on the other side of the core.
If  you make the core thicker....at some point the polarity of the end of the core opposite the magnet will flip.
It is my opinion that  you want this point were the magnetic field  flips to be near the middle of your core
If the point where the polarity flips is within the field of your coil  just a small input to your coil should flip the polarity of your core.
A way to test the basic setup might be to adjust just one coil at a time.....  I think I would adjust each coil for the most BEMF from a outside signal like a signal  gen
I would  be trying to get each set of coils working like a magnicoaster ....then I would adjust  my power input  to the coils to minimize cogging
gary
Edit
I got it wrong
Using your input to the coil to tune  for cogging  is  not the right way.
Romero said  it has to be tuned over and over.
First it has to be tuned for minimum cogging
Then the coils would  have to be tuned like magnicoasters
This tuning will screw up  your cogging......so you will have to tune it again........This tuning will screw up your magnicoaster tuning.......but with each tuning you will get closer to the ideal setup
gary
resonanceman
Quote from: webby1 on June 03, 2011, 07:50:27 PM
One other thought that I keep going back to is the fact that Romeros' motor was pulling .94A just spinning, which with the few others we have seen running with a much lower draw, so that is making me think that he has "tuned" his motor for a max output value similar somehow to Thanes accelerating generator.
I agree
Remember he said tune it under a load.
gary
REDCAR1957
If I may ask what are you using ? and what is your results with what you are using?
KC
