Muller Dynamo
0 Members and 50 Guests are viewing this topic.
nul-points
Quote from: penno64 on June 04, 2011, 03:58:48 PM
I also feel, both drive coils are NOT working in attraction mode - but am yet to prove this.
Kindest Regards, Penno
LOL
when i pointed this out several days ago, based on photo evidence of the position of Romero's Hall sensors relative to their drive coils,  i got told i was "making stuff up"!!!  :)
Quote from: nul-points on June 01, 2011, 08:35:24 AM
looking carefully at the still shots of Romero's device it appears that he only changed ONE drive coil to attraction mode and left the OTHER drive coil in repulsion mode
the sequence, looking from above, is 1st drive coil in repulsion mode, then 1st Hall sensor, then 4 gen coils, then 2nd Hall sensor, then 2nd drive coil in attraction mode
you can still see the hole in the top stator plate where the 2nd Hall sensor used to be and it is AFTER the 2nd drive coil (exactly like the 1st Hall sensor is AFTER the 1st drive coil)
originally both sensors would have been able to use the small mags on the rotor rim, because the relative position of each sensor was the same to its connected drive coil -AFTER TDC
but when Romero changed the 2nd drive to attraction he needed the sensor to fire BEFORE TDC, so he moved the 2nd sensor over the top of the rotor mag path, BEFORE the 2nd coil
so - this COULD mean that the two drive coils were firing either simultaneously, or at least very close in time
np
Here are a couple of Romero's Posts regarding firing.
Why is it some of you guys want to start making stuff up?  ???
oscar
Hi woopy, Lidmotor, penno64 and All
thanks for sharing.
Maybe the impedance needed on the load side of the circuit does not have to be provided by the main input battery nor by a cap.
Maybe any DC-source of the right voltage on the load side will produce the desired effect.
So I propose the following experiment:
Find  a battery with a lower voltage than what your generator coils supply to the load (under load). Connect this battery to the output side of your machines. It has to be connected anti-parallel as per woopy's circuit drawing in reply #2432 http://www.overunity.com/index.php?topic=3842.msg289518#msg289518.
Again: the voltage of the 'opposing output-side battery' needs to be less, than what the coils produce under load. To make such an output-side battery of the desired strength, small batteries can be connected in series.
The transmission was a '53 (Johnny Cash)
Bruce_TPU
Quote from: penno64 on June 05, 2011, 12:06:02 AM
@woopy,
Untill I get the video camera -
1.  20v @ 200ma  + 6.8uf ac cap = 1800rpm
2.  20v @ 400ma no cap = 1630rpm
Great job Penno64!  A huge find that ALL replicators should take note.  Did you randomly choose the 6.8 uf value, or have you tuned it to resonance, to match the frequency of the pulse to the output coil?  That may result in interesting results as well.
Cheers,
Bruce
woopy
Hi Penno
Le loup sort du bois :D
Bravo man now i see better.
You know as i am far from being an expert ,for me it is very difficult to imagine what the people are saying. And that  especially when the problem is not very clearly explained, and even in this case it stays difficult. So i prefer seing the things.
Nice built and waiting for your result under load.  Excuse my somehow rude words from yesterday i was just a little nervous after a complete day of trial and error and having fried 4 reostats . But today is another day and i go on and wish you all the best Thanks
@Free
bravo hehe always more replicators and hopefully more results ;)
@Gyula
thanks for the resistor advice i began with a 470 ohms and it is better. But always very far from Romero. will try to optimise the driving circuit with other resistors, Thanks
@Oscar
Thanks for the prop will test it also
And bravo to all other not known replicators, perhaps one will crack the trick and report ? ::)
good luck at all
Laurent
