Muller Dynamo
0 Members and 199 Guests are viewing this topic.
i_ron
Quote from: 4Tesla on June 06, 2011, 04:47:49 PM
Can anyone answer my question about drilling acrylic in my previous post?  Thanks!
Yes it will work but be advised that this may cut an oversized hole.
I assume you have a drillpress? Clamp the work down, go slow, high speed in acrylic tends to melt the pieces back together.
I have used a spade drill to drill acrylic and that worked well, nice light press fit for the magnets. I drill a small pilot hole first
Ron
Magluvin
4Tesla
You can buy bits specifically for plastics, most likely at a plexi store.  For larger holes use a quality UniBit. If they are just used for plastic they will stay sharp for life. ;]
Also a fine laminate blade in a jigsaw will give pro looking cuts.
Mags
toranarod
Quote from: hartiberlin on June 06, 2011, 10:51:52 AM
How does the green voltage waveform look then when you do this shorting ?
Do you use only driver coils and use them also as pickup coils ?
Many thanks.
this is only 1 drive coil pair.
l need to show a circuit diagrams to help me understand this.
its wave forms and circuits are very interesting
I shorted the coils and added the tuned capacitor to the output and was able to get output current to 600 m Amps the voltage was so high it heated up the capacitor and destroyed it. the capacitor was rated at 160 volts non polarized.
there is so much to test.
The drive current was 100 m amps.
Is this OU? don't know as Power calculations are not available yet. I need to collect much more data to established an RMS voltage.
the divisions are 5 volts on X ten. each division is 50 volts
toranarod
Quote from: romerouk on June 06, 2011, 12:42:31 PM
Well done @minoly, can you confirm for all others that the speed goes beyond the normal speed without the coil in place?
Hopefully now people will pay more attention to what I said many times before. I have never lied and I made statments only confirmed by myself during my experiments.
I have mentioned the Kromrey effect few times before but it was ignored because for some people this is too simple to be true and work.
As you all can see it works, and when you will understand more about it you will manage to do this much more easy.
I wonder why for all this time nobody ever managed to see this effect except Thane , but that in my opinion is a little bit different.
Why Muller's daughter continues her father work if there is no benefit?
This was my question when I decided to go for this Muller setup.
Best Regards,
Romero
I am happy now :)  this is good news. 600 mill amps output. :)
Dave45
Do you short the coil all the time or is it pulsed using the hall switch.
