Muller Dynamo
coke2k
http://www.youtube.com/watch?v=GDydJnqB4jE
this experiment has been made long ago, but I think it would be useful ... (by  user teofilius)
wings
about shorting read EMdevices
http://www.overunity.com/index.php?topic=10716.msg289867#msg289867
by adding a capacitor in parallel with coils (before diodes) there is only resonance effect and you loose energy : ??sorry I am not sure about that??
" 2)  the pulses (current conduction) occur around the maximum induced voltage, when the voltage increases ABOVE the output capacitor voltage.   RomeroUK's dynamo produced around 15 Volts unloaded, and 12 volts when loaded with that 12 volt light bulb,  and on the graph below I drew the red lines where this corresponds on the normalized curve.   (12/15 = 0.8 ) "
you have also to drain energy from capacitor in order to stabilize the right voltage and conductance effect, the value of capacitor have also great influence on the dynamic of discharge .
minoly
Quote from: wings on June 07, 2011, 06:23:26 AM
This is interesting, I must be doing something wrong.
I have a pickup/gen coil, goes directly to a FWBR then to a 12 volt bulb which is in parallel with a cap. this is the normal part, the bulb lights a little. when I put my voltmeter across the bulb, the voltage reads 2.03 volts.
When I add a "cap short" across the coil. the bulb light increases slightly and the volt meter rises to 2.56 volts - at the same time the rpm increases a tiny bit. which is why I am headed to the store to pick up more caps :-)
this method is not as sure as Bolt's amplified short, but I thought it might be worth exploring anyway - for its simplicity. it's definitely not as dramatic. leave no stone unturned.
toranarod
Quote from: minoly on June 07, 2011, 09:20:12 AM
I have the same affect.
if you adjust the timing you can squeeze a bit more out of it. I tuned my motor over the last 24 hours from 100 m amps the 400 m amps and then to 600 m amps to 900 mill amps before i burnt out the coils.
you will find the right value will give the best results. please try the cap where i put it in my circuit you will not be disappointed.
Romero said he picked the muller for this technique. its the technique thats important not the muller motor so much.
I am going to run some test on my other motor using the same technique as i have on the muller.
My Adams motor is larger and can handle the abuse . It has .5 ohm 9 m H coils 6000  Gauss magnets.
I also had it at COP 1  so close it stabilized its battery.
   good work and good luck
keep us posted
cheers
FreeEnergyInfo
info miuler neogen
Replicação Neogen (BILL MULLER ) by ROMEROUK. rotor 8 imas 3cm x1cm,9 pares de bobinas fio21 awg 400 voltas cada. circuito driver com 3 transistores 2N3055. pulso com sensor reed switch.utilizando 2 baterias 12v.
http://www.youtube.com/watch?v=qfbXLKl1z84
http://www.youtube.com/watch?v=U3Mqbtwi3aY
http://www.youtube.com/watch?v=LCqgjhdWgt4
http://www.youtube.com/watch?v=GXOofvSr6lY
Energy-from-the-Vacuum-Part-2...ENGLIS
http://www.youtube.com/watch?v=WS-XAxxuZXA
HD
http://veehd.com/video/4593053_Energy-from-the-Vacuum-Part-2  4:32:06
http://veehd.com/video/4571292_Energy-From-The-Vacuum-Bedini-Bearden-Part-1-divx  2:08:05
Energy-from-the-Vacuum-Part-2  rus
http://www.youtube.com/watch?v=eupTIwqwzb4  2:14:50
