Muller Dynamo
0 Members and 49 Guests are viewing this topic.
4Tesla
@konehead and kishbud
Thank you for the tips and links!
@all
I don't see any reason to have parallel diodes on the rectifiers.  I have researched and can't find any advantage.  I don't believe this is key to the selfrunner.  From what I have read, two diodes in parallel will allow more current only if they have the same specifications, better to just get a higher rated rectifier.  Two diodes in parallel doesn't change the voltage drop.
Arthurs
Hello everybody:
Important Prompt: [/]
    Romero display devices and never published information on the reference to "coil short", We do not walk the wrong road.[/]
    About the "coil short", I did a variety of experiments, it can only increase the voltage, reducing the current, the energy can not be enlarged.[/]
Bruce_TPU
lumen
I think if someone is bent on adding a circuit on coil shorting, it should be after the bridge and the shorting should be into the capacitor.
This would possibly give some unique control as to the lenz forces on the approach and departure depending on the switch timing and yet all power would go into the capacitor instead of just shorted to ground.
neptune
@Arthurs . I am not sure that I fully understand your last post . your second sentence reads "We do not walk the wrong road ." From that I assume we are walking the right road . I suspect you could well be right in that coil shorting can only increase the voltage and not the power , but this is NOT based on my own experiments .
     However , as I understand it , coil shorting has other benefits , delaying the Back EMF so that it actually ads to the motors effect rather than causing back drag . That is a benefit in itself .
