Muller Dynamo
0 Members and 45 Guests are viewing this topic.
scratchrobot
Quote from: neptune on June 07, 2011, 04:11:22 PM
@Arthurs . I am not sure that I fully understand your last post . your second sentence reads "We do not walk the wrong road ." From that I assume we are walking the right road . I suspect you could well be right in that coil shorting can only increase the voltage and not the power , but this is NOT based on my own experiments .
     However , as I understand it , coil shorting has other benefits , delaying the Back EMF so that it actually ads to the motors effect rather than causing back drag . That is a benefit in itself .
Only one person knows but he can not tell us, we have to waste more time and money ourselves  ;)
Instead I would rather work on improving the concept or build a solid state version.
http://www.youtube.com/watch?v=cuhZ5ipW31U
Regards,
scratchrobot
teslaalset
Don't forget, using the rectifier and a big buffer capacitor does a pretty good job in approaching shorting the coils when the induced coil voltage is passing 2 times the diode threshold voltage + Capacitor voltage.
In case the rotation speed is sufficiently high, the capacitor impedance is also very low.
In that situation the diode resistance is dVdiode/dIdiode, which is a near shortage.
So, I am not sure I understand all the fuzz about extra shortening circuits to be honest.
[edit]
In case some of you would like to persist using extra shortening circuits, keep in mind that ultra short pulses will not do anything extra.
You need a decent period of shortening.
In that case, how would you like to collect energy from a shortened coil? It will only waste energy through heating up the coil.
The extra gain you get from delayed BEMF will already be lost in the coil presumably.
scratchrobot
Quote from: plengo on June 07, 2011, 01:10:10 PM
It is Arduino Duemilanove board. And I am using one mosfet IRF610 to switch the coils. The meter is on the input side so that I can see in detail what is going on.
Fausto.
I have a board like that and maybe try it on my motor also, can you show me how to connect it to the mosfets and driving coils and maybe how to connect a hall sensor to the arduino?
http://www.youtube.com/watch?v=7ZFIMqA0Vpc
Regards,
scratchrobot
gyulasun
Quote from: scratchrobot on June 07, 2011, 04:30:20 PM
You seem to be doing fine with the rotary version, solid-state version can come later when we can master rotary version...
How your input power (current) changes when you turn the back magnets and RPM goes up?
Thanks,  Gyula
scratchrobot
Quote from: teslaalset on June 07, 2011, 04:35:09 PM
I have to agree with Neptune.
In case the rotation speed is sufficient high, so the capacitor impedance is also very low.
I agree I think there has to be some sort of self shortening effect goeing on like you describe!
When I see the Kromrey converter I also see no shorting circuit but a constand 100% short.
Regards,
scratchrobot
