Muller Dynamo
0 Members and 302 Guests are viewing this topic.
totoalas
Hi Romerouk
As neptune suggested with ceramic magnets from microwave ovens
Im interested with the output  wattage it can produce????? ???
Also instead of the driver coils ,   i will try  the rotor from a vacuum machine  with carbon contacts  direct dc  to rotate the magnets
http://www.youtube.com/watch?v=1q4QRFELr5A&feature=channel_video_title
Trying to replicate the set up on a low budget
cheers  and regards to Groundloop ::) ::)
totoalas
neptune
@bourne. many thanks for that calculation . With home made multistrand  it will never wind as neat as you expect . I recomend adding 40 to50% to the calculation for the first try . Then you can refine the length as  I previously said .
bourne
@neptune.
Thanks, It's an 'ideal world' calculation and of course does not include tails and imperfections.
I thought I would post it because the difference between layer1 (785mm) and layer12 (1821mm) is quite large and may lead to underestimating the length needed to complete 300 turns.
This is a great thread.
There is but one true power in the Universe... that which we call Love. Todays present label and conspicuously absent from our named guardians tool kit.
toranarod
Quote from: neptune on May 07, 2011, 02:44:03 PM
Further to Bruce`s post above . How to make your own Litz wire for these coils . Get some enamelled wire with a diameter of 0.125 mm . Your local electric motor rewind shop is a good source .This wire is very thin so work carefully . First and hardest part is estimating the length of wire needed for each coil .Let us guess , an average length of one inch per turn . So 300 turns would be 300 inches or 25 feet . If your workshop is less than 25 feet long , work outside . Mount 2 hooks 25 feet apart facing each other , on wall bench clothes posts etc . Attach the loose end of your wire to a hook , walk to the other hook , loop the wire round it and walk back . Walk back and forth 7 times , looping at each hook until you have made 7 trips .Tie off the wire at the hook and cut the wire . Bind the 7 strands together with tape near each hook . Now slip one end of the bundle off a hook andput a screwdriver through the loop where the hook fitted . Use the screwdriver to twist the strands together loosely . Cut off the loop at one end and carefully remove the enamel and solder the wires together . Use this end to start winding your coil , and wind the desired number of turns .You will then probably find your bundle was too long .cut off the excess and measure it .   Subtract its length from 25 feet , and adjust your hooks for the next performance . Finally strip and solder the ends together .Hope this will help someone .
thanks thats a great idea
I have the wire never accrued to me to wind my own.
FreeEnergyInfo
Hi All,
here are now the backups of the RomeroUK Videos:
RomeroUK + Muller generator = 10 W free energy HD
http://www.youtube.com/watch?v=T1lBhkZI7Ds
