Muller Dynamo
0 Members and 120 Guests are viewing this topic.
e2matrix
Everyone needs to see that video lasersaber put up.  I think we are already heading in this direction from seeing some recent posts but this seems to confirm it.  Reversing the top coils seems to stop the Lenz law effect.  He also shows a rather dramatic increase in output just by adding the magnets.
    Lasersaber if you are around can you verify that you just reversed the wires on the top coil OR did you have to physically turn the coil upside down?  There was some difference of opinion on this facet on another forum as to which way works.
yssuraxu_697
Quote from: lasersaber on June 09, 2011, 11:31:43 AMQuick update.
Cool. As I concluded here from "rom's trace"
http://www.overunity.com/index.php?topic=10716.msg290145#msg290145
there was phase shift - not physical but indeed "virtual" created by magnets.
Interesting - if you would scope voltage or current would one of them match "rom's trace"...
lasersaber
QuoteLasersaber if you are around can you verify that you just reversed the wires on the top coil OR did you have to physically turn the coil upside down?
I just just reversed the wires on the top coil.  The effect is really neat.  Until I added the additional magnets I thought the there was no power generated in this config at all.
Check out what MileHigh has to say about this effet over on the other forum:
QuoteJust a few thoughts relative to the project:
Reversing the wires on the generator coils will have no effect.  You just create a mirror-image inverted voltage waveform.  That waveform passes through the FWBR so you end up with essentially the same thing.  Doing experiments where you swap the wires of the generator coils is spinning your wheels. You could be doing more productive things with your time.
The switch-on speed of the diodes should be a non-issue.  I am pretty sure that diodes switch on in a few tens of microseconds or much faster than that and your motor at full speed operates on the tens of milliseconds time scale.
chrisC
Quote from: lasersaber on June 09, 2011, 12:24:19 PM
Yea. We know about Mile High and his know it all attitude. He needs to be Low Down to see where the action is and to learn a trick or two. That's why he is banned on this forum.
Thanks for your efforts LaserSaber.
cheers
chrisC
Pirate88179
Laser:
So Milehigh says there is no effect from this?  But, we can clearly see an effect.  So, I guess Milehigh is wrong...imagine that.  It isn't the first time.  He was also misinformed about the JT circuits and supercaps.
