Muller Dynamo
0 Members and 50 Guests are viewing this topic.
Artist_Guy
Quote from: nightlife on June 11, 2011, 12:33:38 AM
Come on guys, think hard about what you all are talking about here. I see many mistakes and a lot of energy waste. The way you all are talking, you all are going to waste more then twice the energy needed.
@nightlife  What are you referring to specifically? What will waste twice the energy?  Adding diodes between the N-A & S-B coils?
gotoluc
Hi everyone,
@Bruce, very good ;)
I'm quite sure this could be done with low resistance MOSFET's instead of diodes! ... so could be next to no losses.
Has anyone noticed a Metal (aluminum or steel) tube ring around Romero's rotor?
Thanks for sharing
Luc
4Tesla
Bruce,
I see how the coils could cancel each other, but are you sure about the diodes?  I don't see them on Romero's dynamo.
Thanks
teslaalset
@Bruce, I don't see the solution you see here.
From what I understand is basically two coils at the same clockwise position (as you indicate in your figures) are connected anti-series.
In that case EMF is cancelled out, but so is the current caused by that (Kirchhoff's law)
No current, no load power.
So, what am I missing here?
baroutologos
@baroutologos
I am capable enough to build even more complex ones and you have no idea how many I built and tested in maybe hundreds of experiments I did.
below is a picture with one of the best I ever used, where the simple one PNP transitor was using 230ma to drive a motor coil this one in the same circuit used only 90ma.
the rotor was almost 6kg and magnets 35mm dia/40mm long
I have the coil connected ''wrong way'' as you say but I might have had a reason to use it like that, don't u think?
Anyway...
All the best,
Romero
Romero, how are you?
yeap, even the circuit proposed (is common on the adam motor experimentalists) is a bit wierd, "the wrong way coil connection" as i see it has its merits so as not to destroy the circuit at first glance by restricting current. Anyway, even small "stupid looking things" have their beauty i must confess.
