Muller Dynamo
0 Members and 50 Guests are viewing this topic.
lanenal
Anybody knows how to convert a .stp or .stl file into a .dxf or .dwg file? I used FreeCAD to produce the CAD drawing of the rotor and stator (which can be only saved in .stl, .stp, .igs, and .brep formats), but the workshop only accepts .dxf or .dwg. It seems they have got a automated system that can produced according to CAD drawings.
romerouk
Quote from: poynt99 on June 11, 2011, 06:52:11 PM
So I would surmise Romero, that you have discovered a way to make a coil of special configuration and/or connection, that utilizes an alternating magnetic field presented to the face of its core, in such a way that loading this special coil has little to no effect in terms of causing drag on the rotor (alternating mag field) or cemf within itself?
Does the next logical step then involve taking advantage of the same effect by means of direct juxtaposition of the drive coil and collector coil, thus eliminating the rotor and magnets all together?
.99
I am thinking of a alternative with SState but believe me it is not easy. So far I cannot picture a solid state device, I need to spend too much time for that and is not my intention now as I am in a busy period.
In the recent youtube video I am using for load only one side of the ac wave to power the LED's, the other side is used to keep the rotor rpm stable.
When we work with a coil and a movable magnet it is much easier than having a coil/fixed magnet.
penno64
So from this we can conclude that it is bifilar wound.
Using one end and CT to leds and the other end and CT back to drive coil.
Penno
hadcat
Quote from: lanenal on June 11, 2011, 07:01:06 PM
Here is how to convert stp to dwg.
http://www.ehow.com/how_7502016_convert-stp-dwg.html
lanenal
Quote from: hadcat on June 11, 2011, 07:30:50 PM
Thanks hadcat, I tried it but it crashed right away...it might be due to my system.
