Muller Dynamo
0 Members and 251 Guests are viewing this topic.
toranarod
Hello
I have just made another Video.
I have been doing more research about accelerating under load.
I will make a better video with some circuit diagrams.
Hope this helps
cheers
http://www.youtube.com/watch?v=VoR38JgJTYE
Tudi
might be off topic : if i understood correctly, a testla tower is a pure potential( V ) energy transmitter. That means the I and V phase difference is unlimited. If you say that Lenz happens because of I, then there should be a way to create a generator based on tesla tower that does not generate any Lenz effect ?
Awe
Hi Everyone,
I’ve been following silently since day 1 and have also attempted a replication of this generator. Unfortunately my results are the same as everyone else…  No magic  :(
At first I’d fully populated the generator with the pickup coils, connected through FWBR’s and all paralleled to see if I could at least get 1:1, but alas, Lenz would take over at any sign of a load and slow the rotor down. I had tried the stator magnets trick, and adjusting the gap between the rotor and stator coils, but no joy.  As someone wrote earlier in this thread, +1 here for -1 there.
The pickup coils are the same (I assume) as Romero’s. 20mm-ish diameter, 10mm-ish height, 6mm core (sewing machine bobbins). I’d installed 15mmx6mm ferrite cores cut down from 40mmx6mm store bought. The litz wire I used is 7x0.190mm, as wires.co.uk had run out of the 7x0.125mm. I understand the wire is a different diameter from what Romero used, but after all the testing I’d performed using other wire I have; I doubt it’d make the difference.
As I’ve been testing for the past week with different combinations and toying around with different ideas, I’d removed most of the pickup coils and set focus on 1 single pair of pickup coils. Photos below show my progress.
On a side note, I kindly urge anyone else who’s tried replicating to come forward also, just so we can have a running tally of how many replications have been attempted...
Thanks.
TheCell
Hello
this rotoverter theory , which depends on resonance:
IMHO this is not the whole story: if a cap parallel to the coil is connected, first measure the frequency of the standing wave of the generator coil .
This is measured without the parallel cap that is connected directly to the generator coil. Then chose the right cap value to get the resonance frequency equaling standing wave frequency.
This is the way a delamorto tuned his kapanadze like primary coil.
Does this apply here?
Arthurs
Please note that romerouk video in:
    Drive coil and the generate coil wire leads, not that we use two, the extra wire leads connected to?
    Are between the drive coil and the generation coil connected to each other?
    Or should be concerned about his "special coil"
