Muller Dynamo
0 Members and 61 Guests are viewing this topic.
poynt99
keykhin,
How do the results compare when you do not use the parallel capacitor?
Thanks,
.99
penno64
@all
Sadly, I don't think that I would be able to cope with a gazillion questions (llike Romero did), so I need to be careful how I say this.
I put the dynamo back on the table yesterday afternoon. Thought I would try a couple of different
things.
I can tell you that the magic happens when everything is connected.
From the first pickup coil pair, I was only getting very few millivolts. But once all 7 were connected,
the unit begins to produce real voltage and current.
It was only due to poor workmanship on my part, that sitting there watching this thing go round, I could see arcing at one of the pickup coil pair connectors. I had connected a parallel cap to each
pair using those short leads with aligator clips and one of the clips was oh so close to the next pin.
You guessed it, putting a dead short on one of the coils, the system did not slow much but the voltage and current went up .
What more can I say other than, a big thank you to Romero and the rest of you guys for
putting up with my silly and sometimes annoying posts.
I am going to try and purchase a DC-DC converter today and I promise to let you know
how it works out.
Kindest Regards, Penno (Garry)
penno64
@Neptune,
Thanks for that.
Is there a way to turn off PMs ?
Penno
gyulasun
Hi Penno,
Perhaps you may wish to briefly describe:
your input voltage used and input current?
Output DC voltage across the big puffer capacitor (by the way,how many uF in value is it)
Say you have 14V DC output voltage, then try to choose a normal load resistor which gives say two times as many load current as you input current, just for curiosity, till your DC-DC converter arrives.
And maybe some pictures of the present setup?  And do not change it till the converter arrives...  maybe gently fine tune the cores with ceramic magnets...
Gyula
FreeEnergyInfo
http://www.youtube.com/watch?v=mG8g7EtsPaQ
http://www.youtube.com/watch?v=Js3lTXFuBj8
REPLICAÇÃO NEOGEN BY ROMEROUK (BILL MULLER MOTOR ) .9 PARES DE COIL COM 400 VOLTAS FIO 21AWG .NUCLEO DE FEERITE MISTURADO COM RESINA E MAGNETITA . ROTOR EM ACRILICO COM 8 IMAS DE 3 CM X 1 CM NEODÍMIO .2 BATERIAS DE 12V DC ,PULSO COM SENSOR REED. 2 PARES DRIVERS COM 3 X 2N3055 .7 PONTES RETIFICADORAS E 2 CAPACITORES DE 400V X 3300MF PARA FILTRAGEM.UM TRANSFORMADOR 12+12/110V PARA CONVERSÃO AC PARA ALIMENTAÇÃO DAS LAMPADAS.TENSÃO DE ENTRADA 24VDC CORRENTE DE ENTRADA PARA CADA DRIVER APROXIMADAMENTE 0,70A .QUANDO COLOCO IMAS NA PARTE EXTERNA DO FERRITE ESTA CORRENTE CAI PARA 0,36 A.NÃO PUDE MEDIR A VELOCIDADE ,POIS NÃO TENHO AINDA APARELHO ,MAS PELO VIDEO A ROTAÇÃO É MUITO BOA.
