Muller Dynamo
0 Members and 54 Guests are viewing this topic.
TheCell
@Jdo300
Did Multisim confirm the overunity effect?
The values you published where these of the Java simulator.
teslaalset
Question to the wizz kids here:
Do you think the coil has a fixed inductance during rotation?
I don't think so.
The ferrite probably is driven into saturation when magnets approach.
Meaning the inductance can vary about a factor of 100, having in mind the permeability of ferrite is varying from say 40 - 4000 during rotation.
[edited]
xenomorphlabs
Quote from: bolt on June 13, 2011, 11:34:24 AM
Cascaded systems are where the generator coil is tuned to yet another coil sub system that runs at entirely different frequency. Usually the prime frequency is very high in the hundreds of Khz this creates inference to the 2nd RLC but its NOT parametric perhaps running hundreds of Hz.  This then goes to a 3rd stage at even lower frequency say 60 Hz. Each layer provides greater source to load isolation so the the COP's are cascaded.
Would it be possible for you to briefly describe how to transfer energy from one RLC stage to the next (at a different frequency) WITHOUT parametric variations/coupling? What would the stages have to be tuned to for this to work as you describe?
Interferences between circuits usually don't (fortunately) automatically transfer huge amount of energy, so what needs to be different?
Thank you
bolt
Quote from: FreeEnergyInfo on June 12, 2011, 04:48:11 PM
http://www.youtube.com/watch?v=mG8g7EtsPaQ
http://www.youtube.com/watch?v=Js3lTXFuBj8
REPLICAÇÃO NEOGEN BY ROMEROUK (BILL MULLER MOTOR ) .9 PARES DE COIL COM 400 VOLTAS FIO 21AWG .NUCLEO DE FEERITE MISTURADO COM RESINA E MAGNETITA . ROTOR EM ACRILICO COM 8 IMAS DE 3 CM X 1 CM NEODÍMIO .2 BATERIAS DE 12V DC ,PULSO COM SENSOR REED. 2 PARES DRIVERS COM 3 X 2N3055 .7 PONTES RETIFICADORAS E 2 CAPACITORES DE 400V X 3300MF PARA FILTRAGEM.UM TRANSFORMADOR 12+12/110V PARA CONVERSÃO AC PARA ALIMENTAÇÃO DAS LAMPADAS.TENSÃO DE ENTRADA 24VDC CORRENTE DE ENTRADA PARA CADA DRIVER APROXIMADAMENTE 0,70A .QUANDO COLOCO IMAS NA PARTE EXTERNA DO FERRITE ESTA CORRENTE CAI PARA 0,36 A.NÃO PUDE MEDIR A VELOCIDADE ,POIS NÃO TENHO AINDA APARELHO ,MAS PELO VIDEO A ROTAÇÃO É MUITO BOA.
Olá,
Muito boa máquina que você produziu!! Eu posso ver que você fez bobinas de alta voltagem isso é melhor introduzir uma grande indutância que muda o ângulo de fase de alimentação.
Olhe para ver como você pode adicionar capacitores para as bobinas e afinar cada um para produzir a tensão máxima na velocidade do rotor completo.
Pode ser melhor para você traduzir para Inglês por você futuros relatórios.
Boa saúde!
scratchrobot
I don't think it's the RPM  ???
