Muller Dynamo
0 Members and 44 Guests are viewing this topic.
gauschor
Edit: hmmm...must be considered
bolt
Yes first there is an odd number of coils to magnets this helps prevent no load cogging as each field is overlapped. But under load it begins to bog down again UNLESS the cores are Re-gauged.  By adding another magnet to the back side of each coil the coil once pulsed becomes latched in north or south pole state. Lets say the coil is latching South it approaches a South facing magnet and tries to repel against the coil. Normally the greater the current from the last magnet pass the greater the latching as it approaches a new magnet so the lugging increases.  The Re-gauging RESETS the coil by forcing back the flux in the opposite direction but it actually over shoots! This creates a north biased coil attracted fast to a south pole magnet and provides free acceleration energy into the system.
The solid state version of this is called ....wait for it = MAGNACOASTER. :) This is why magnacoaster has 5 neos one end and one the other with a measured tuned GAP. Yes its OU.
More abrupt the process is Bloch wall modulation where the return or re-gauging bias is an over shoot of energy from the back end magnet.
romerouk
Quote from: bolt on May 07, 2011, 08:24:23 PM
:) the magnets on top of the coils ideea came from Magnacoasters, I am working on that too but nothing like OU there yet. I am using the computer to generate the pulses.I do believe that Magnacoasters is genuine.
The rotovertor versions I tried about one year ago had about 33w minimum, in my case nothing like 10w or so but I did not oped the bearings to clean them.
romerouk
I had an ideea and went back to the generator.
I was adding small ferrite magnets 20mm diam/0.5mm thick on top of the existing coils and the input now is reduced to 0.78amp and the speed is increased a bit.
I will play a bit more tommorow.
bolt
Quote from: romerouk on May 07, 2011, 08:38:05 PM
Well i made a good guess then (educated one) LOL  Of course solid state is the goal and you will get there very soon. I think everyone has to go through the learning curve of OU machines first then later solid state.  Like you i KNOW magnacoaster is real and you have just proven it beyond any doubt with your generator. It just opens a new can of worms in controlling the HUGE amount of OU power. Plenty of burnt coils and blown fets.
Well when you make your big machine go get that old RV out the shed take off the fan, clean the bearings in petrol and  WD40 and just add one drop of sewing machine oil. It should spin by hand for 40 seconds very easy. Now you got a very efficient motor that can run on 10 watts and use ALL the coils as genheads. A small 250w inverter will run the RV motor easy and just retune the run cap to match the rotor at full rpm and load.
BTW you should get some sleep its 2 am:)
