Muller Dynamo
0 Members and 36 Guests are viewing this topic.
woopy
whoww !!
@ Marius and Erik
fantastic work mans
Now we are biginning to get a real replicator community
So be prepared to be very disapointed in the first run as you will try to get out of this machine the NORMAL OUTPUT. you will be decieved for sure
But if you try to get out of the box, and i know we are not at all prepared for this experiment,    than we get a chance
this machine does  have special feature ( odd / even ration between coil and magnet ) which produce an accelerating ratio from normal magnet passing to something that can be very interestring.
So don't be discouraged by the first result ( i mean Mister Lenz at work it is quite normal as per standard dynamo ). and spend a lot of time simply  study the device at work, and measuring and asking question and and and
This is a beautifull experience   and the aim is not to purify this world but to get  ( or not but it is not very important ) a chance to simply improve ourself.  and by doing this to get a lot of  fun (after probably a lot of frustration)
good luck at all
Laurent
erikbuch
Thanks alot Laurent! Allready been over at mr Lenz for a visit, but I'm not planning on staying there for long ;-)
@Bolt: I'm not so known in the world of electronics as a lot of you guys here are, so I was wondering, what kind of capacitors should we try. Not electrolyte caps if I am getting this right. I was searching for ac caps, but there where alot of types to choose from. Will audio caps do? ceramic? Polyester film? Polypropylene? Some where called motor caps, they where square shaped.
Sorry for my lack of knowlage
(Maybe a flux-capasitor will do it :-) Well, that will just take me back to the future )
Best regards
Erik
i_ron
Quote from: bolt on June 17, 2011, 03:57:46 PM
As always diversion to "measurement errors."
Truth is not a diversion. We had this out last year when Doug announced his "easy 100 watts OU"  I pointed out the 'measurement error' which you failed to see or acknowledge. All he had to do was add the rest of the coils... well? nearly a year later and I haven't seen any sign of it?
Now on Doug's crowbar experiment you claim 3.4 OU. Where is the proof?
This is just grandstanding on your part and pollutes the list.
Ron
romerouk
@mariuscivic
careful with that HDD motor that holds the rotor, it is not strong enough when run at high speed and apply load to the output coils.If that breaks it can do a lot of damage, to you and the coils too.
Make sure there is no other people next to you when experimenting, that can hurt badly.
mariuscivic
Hi woopy!
Allready dissapointed about Lenz but I'm not givin'up.
Allready made some conections(just playing) and voltage rised from 16 to 44.
When I'll get my all driving coils working I'll get it tunned
