Muller Dynamo
0 Members and 429 Guests are viewing this topic.
erikbuch
Nice experiment mariuscivic!
When I had both coilpairs in attraction mode I found out aswell that magnets on only one driving coilpair will increase the speed,
The other coilpair did not respond positive to magnets at all, nomather wich direction i put them.
Romero said something about he run one drivecoilpair in attraction mode and the other in attraction but also a littlebit repulsion??? Nothing to do with the dynamopart anyway, just thougt I would mention it.
Best regards
Erik
erikbuch
@k4zep I see in you schematic you put the cap in parallell with the coils, what happens if you put it in series as Bolt says?
PS: I thought that was a professional video! Be yourself, that is the best you can be!
Best regards
Erik
konehead
Hi Ben
i too noticed that you have the 10uf cap in paralell, and "should be" in series according to the Bolt-theory....
konehead
Hi Mariusivic
Watched your video - nice machine and easy video to view too - are you shorting single coils then that are not connected to that light bulb then?
What happens when you rectify and put different resitsive loads on those coils that make it speed up under short, instead of the dead-short?
Can you get speed up with a resistive load?
I could be that there are some coils that are sort of restricing the rotation, and the shorting cancels out the restriciton they cause, and that is why some coils dont speed up rotor under shorting, this because of the 9 vs 8 configuration...if you connnect all coils of the 9 all in series for the fun of it for "one big" motor coil as expereimnt you will find that there are two that dont really power the rotor either way so you should go with only 7 in series thats what made me think of that it might be related.
also if you have coil on one side of rotor lighting bulb, and other coil facing it being shorted (is this what you are doing?) then mabye that is causing the speedup, since you have jammed the two "facing coils" out of phase to one another, somewhat like Bolt is describing with an AC cap in series.
i_ron
Quote from: k4zep on June 19, 2011, 03:11:38 PM
Lordy, I said 10 Farad, I meant 10uF for that yellow resonating Cap.
Schematic attached.
Respectfully
Ben K4ZEP
LOL. I heard you say 10mfd...selective hearing.
Anyway, great stuff... will give it a whirl, just as soon as I finish my rebuild.
Is this still with the high ohm coils?
Thanks!
Ron
