Muller Dynamo
0 Members and 39 Guests are viewing this topic.
baroutologos
Quote from: bolt on May 07, 2011, 08:53:13 PM
Well i made a good guess then (educated one) LOL  Of course solid state is the goal and you will get there very soon. I think everyone has to go through the learning curve of OU machines first then later solid state.  Like you i KNOW magnacoaster is real and you have just proven it beyond any doubt with your generator. It just opens a new can of worms in controlling the HUGE amount of OU power. Plenty of burnt coils and blown fets.
Well when you make your big machine go get that old RV out the shed take off the fan, clean the bearings in petrol and  WD40 and just add one drop of sewing machine oil. It should spin by hand for 40 seconds very easy. Now you got a very efficient motor that can run on 10 watts and use ALL the coils as genheads. A small 250w inverter will run the RV motor easy and just retune the run cap to match the rotor at full rpm and load.
BTW you should get some sleep its 2 am:)
If i may speak is BEST everyone to refrain from theories and old unproved concepts and focus on what Romero has ended up with.
First replicate, with all the meaning of the word i.e. not major changes (anyway, every one likes replicas), and then once successfully done, investigate yourself.
@bolt,
regarding RV it maybe work at extremely high electric to mechanic energy conversion in comparison to pulsed motors etc but the effect Romero shows that with load application (i.e. bulb and pulse motor) not affecting even slightly the device is outstanding at least and cannot be seen anywhere! (especially if there is not any considerable cogging torque present)
This is the discovered secret IMO thanks to Romero's experimenting skill and will to share.
hoptoad
Quote from: baroutologos on May 08, 2011, 02:40:24 AM
snip..
This is the discovered secret IMO thanks to Romero's experimenting skill.
Good advice Baroutologos.
Also @ Romero - great stuff and thanks for sharing !
Cheers from Hoptoad
FreeEnergyInfo
Pirate88179
Wow, just got in from work and had to catch up a lot.  Excellent work here everyone.
I submit that Romero has made enough changes and improvements to the Muller device that it is now essentially a new device.  I mean, a car is still a car but there is a big difference between a Model T and a 2011 Corvette.  (Romero's device being the Corvette)
This is astounding work here and exciting times.
lanenal
Very well said. We must first know by replication what it is.
Then only after knowing what can we start considering why.
