Muller Dynamo
0 Members and 55 Guests are viewing this topic.
baroutologos
Hello all,
I want to express my solidarity about the great work collectively done here. Special thanks to Ben and mariuscivic for the moment.
I really start to like the idea, bolt has put to the table (with so many details - contradicting in my oppinion or from a different galaxy coming) that the way to beat Lenz and his action - rection law in those rotor-coil setups is just to appropriately swift voltage phase (that is caused by magnet possition) from current phase (reacftion) so as not to hold back the magnet motion or at least altering the resulting force vectors, so in this way to have a positive outcome.
Really interesting concept... what can i say more? :)
Salutes to all
plengo
Last night I replicated again the acceleration effect when shorting coils. I will create a video tonight.
I also by mistake bought the wrong washers, they are bigger, and guess what? The speed of the motor increased too. The washer has a inner diameter of little bit bigger than 3/8 of a inch as opposed to my previous washer of 5mm inner diameter. Also adding magnets to behind the coils increased speed a lot.
So many variables here.
@Jason, great finding.
@All, sorry for deleted off topic posts. I am lazy to just move things around.
Fausto.
totoalas
Quote from: totoalas on June 19, 2011, 05:44:31 PM
Hi Neptune talking of SWEET SPOT of stator to coil
I tried to use an ac clamp meter instead of neogen coil  and try to rotate the rotor  ns(HD drive magnet)   manually by hand   Moving parallel the clamp meter  with 3 to 5 mm   clearance  passing by the rotor , The reading registered   more than  40 amps  in ac scale with  one top side of the meters  coil  on top  of magnet .....   so an air coil  placement of one side of the top coil will produce  the maximum effect
Dont know if this is relevant  just an observation ??? ??? ???
cheers :)
totoalas
http://www.youtube.com/watch?v=gqWQLZq9UwY&feature=mfu_in_order&list=UL
khabe
Quote from: plengo on June 20, 2011, 09:05:20 AM
Fausto.
Dear Fausto,
Is it so hard to understand why the speed of the rotor increases?
Because opposite magnets ::) when magnet turns away from coil then this COIL SHORTING hangs the the flux of top magnet to go back to his normal position, this flux goes back with time-lag, with delay, flux from top magnet does not come to an end before next magnet arrives ... and next ... and next  ... and as a result the speed of the rotor increases because when the right rpm chosen then rotor magnets have nothing to fight with anymore, no repulsion, no attraction.
Yes :o
And so what?
Also no advantageous useful energy - all spent for deceptive success  >:(
cheers,
khabe
i_ron
Quote from: khabe on June 20, 2011, 11:05:18 AM
snip
You like it?
Yes, much better, lol
May I add to your post?
Do’s and Don’ts of Video Presentations:
1)   Keep the camera steady. Waving the camera around like a hose induces motion sickness in the viewer, and makes the video unwatchable.
2)   The same with zooms and pans, slow and steady
3)   Music: no idiot radio show for background. With recorded music…watch out for copyright infringement and having your video withdrawn. If you don’t have your own home made music or public domain music, then go with no music.
4)   Dress: comfortably, but no bare feet!
5)   Standard Technique: a long shot to set the scene, then a slow zoom in to the field under discussion.
6)   Make your point and move on, the viewer has the option to replay a segment as many times as they wish. Just because you have 10 minutes doesn’t mean you have to make a 10 minute video. If you have 3 minutes of material… make a three minute video.
7)   Lighting, very important for the viewer to see what your message is.
8)   And a final note on JPGs, reduce to 600 X 800, on OU.com especially, to preserve the readability of the page.
Ron
