Muller Dynamo
0 Members and 25 Guests are viewing this topic.
FreeEnergyInfo
Quote from: romerouk on June 20, 2011, 03:43:42 PM
Hi all,
many of you are not even trying to understand the reason I stopped posting more info about this build, try to go in my position and think what you will do. I only find few people who are really trying to understand and replicate this device.If you don't understand it, then is no point to continue, here or any other project, making a copy is not enough.
We have few people here that are really a goldmine for all, konehead, bolt, EMdevices, and few others, and I see many times that most of you are just ignoring their advices escpecially konehead who did try and built FE devices probably more than anyone here.
I have a great respect to konehead because I can see him thinking and building things same like me, not very sofisticated but simple and working and most important is that feeling that not everyone has.
Fake or not fake, this last 2 months showed to many of you a lot more understanding and knowledge than you have acumulated in a long time before, who can tell me that this is not true?
How many of you have experienced before this speed under load? How many of you have played before with coil shorting, capacitor shorting,... ?I am very happy that I brought up this discussions and now many people will start to understand it better.
Has anyone played with capacitors with 3 terminals? What about 4 terminals or 7??
Anyone tried to have 2 identical capacitors one charged and another empty.Now try to make a device that while is using first capacitor power it is charging the second one and end up with more in the second one.Possible??? oh yes it is.I have stated many times before, try easy and simple things before going big and before spending lost of money.I spend about £400-700 every month and i know most of you cannot afford that that's why keep it cheap and simple.
I wish you all the best,
Romero
THANKS...
scratchrobot
Quote from: romerouk on June 20, 2011, 03:51:51 PM
@scratchrobo I like your small testing device, don't deviate and keep it right.
Thanks, you are right, I would not have done this experiment.
bolt
Hi all,
Romero
Romero thanks for dropping in. This thread really needed to hear from you to stabilise the situation about fakes as it was becoming fragmented. Indeed you are right. More information has been disclosed here in the last couple of months than in a couple of decades!! Most of what i share is a result of other peoples hard work an understanding. LOOPING is very real and until people have a very clear mind about this the negativity spreads like cancer and prevents us all from moving forwards.
The most important point is NOT about replications its about understanding the methods and principles to achieve such aims. It matters not if we are talking about Kromrey's, RV's,  TPU's, kapanadze etc the underlying theme between them is all the same.
There are more than one ways of skinning a cat!!
scratchrobot
Quote from: neptune on June 20, 2011, 03:40:55 PM
@Scratchrobot . That looks like a very significant result . From your diagram , it looks like your coils are in the "bucking " configuration . Important question . When you are moving that top coil about to find the sweetspot , are you moving it up and down , so it is in alignment with the bottom coil , or are you moving it side to side ?
Yes they are in bucking configuration. I am moving the coil in all directions. Maybe the sweetspot also changes with the rpm? I think every coil has his sweetspot and should be tuned by moving it in any direction.
bolt
Quote from: scratchrobot on June 20, 2011, 03:22:31 PM
Today did another experiment and discovered that when i put the top coil at the right spot, the spot that gives me the highest rpm then the scope shows me the Kromrey waveform. I don't think this is a coincidence. This time I also used a 47uf cap in series with the coils. I attach a picture with schematic of what I did and the waveforms, left is mine and right is the original Kromrey scopeshot.
http://www.youtube.com/watch?v=juBMUG7Kcsg
I wonder if all coils tuned this way on a muller give a good output.
But most important you didn't have to build a 10 coil $1500  rotating STADIUM to find that out did you? :)  Well done!
