Muller Dynamo
0 Members and 25 Guests are viewing this topic.
penno64
Quote from: romerouk on May 06, 2011, 06:51:57 PM
Hi penno,
Yes I am religious, Christian Orthodox, God helpped me many times in life.
I am curious to see how many will actually do anything, many are just waiting and waiting... don't know what.
Do not use shortcuts, if built like I said, reffering to the coils and magnets arrangement then everything else is easy if not will fail. I will show you how many rotors I have made before this one worked, all others looked perfect but small diferences.
Can you believe that I have ordered 2 of the acrylic rotors to a local company who uses laser cutting and I was expected to get a perfect rotor but... the centre hole is not centered and the spacing betwen the magnets on the rotor was not equal... I went crazy.I paid a lot of money for that operation to be done perfect and their excuse was that I was no very specific that it must be acurrate... what will I expect fron a laser cutting...
The one used now was ordered to another company that makes clock parts but the max thicknes they worked with was 3mm. I have ordered 4 and glued them togheter. The actual rotor u see is made from 4 rotors 3mm thick each.The rotor must be strong and not bend.
Today I have ordered the magnets for the next build and what is left is again the stupid rotor.
I have to go again thru the same pain, oh nooo...
All the best,
RomeroUK
Tudi
Quote from: romerouk on June 20, 2011, 03:43:42 PM
If you don't understand it, then is no point to continue, here or any other project, making a copy is not enough.
I have great respect towards you. Please understand that some of us start right at this project. For learning purpuses this copy is more then enough, it's quite high tech :)
About the coil keeping it's state over time and having a PM magnet on the back to make it flip state to a neutral one : I wonder if this effect could be enhanced in a way. Like an optimization to make the cancelation realy take the coil to a neutral state. Maybe a shorting ? Maybe a short but powerfull pulse ? Maybe a strong electromagnet pulse ? One of those small optimizations that might add up in the end. If we take the L/ R propagation time then it is probably an advantage to have thick wire for the coils ( more I then V ) ?
About caps in series when second one has greater voltage i posted a link a while ago :( Nobody cares :(
hartiberlin
Quote from: scratchrobot on June 20, 2011, 03:22:31 PM
Today did another experiment and discovered that when i put the top coil at the right spot, the spot that gives me the highest rpm then the scope shows me the Kromrey waveform. I don't think this is a coincidence. This time I also used a 47uf cap in series with the coils. I attach a picture with schematic of what I did and the waveforms, left is mine and right is the original Kromrey scopeshot.
http://www.youtube.com/watch?v=juBMUG7Kcsg
I wonder if all coils tuned this way on a muller give a good output.
Well done,
so at some RPMs you definately had a resonance in your LCR setup, so the current at the shunt
had a bigger amplitude.
So try to match better the RPM and the resonance of the LCR tank circuit.
Regards , Stefan.
wattsup
Hi all,
many of you are not even trying to understand the reason I stopped posting more info about this build, try to go in my position and think what you will do. I only find few people who are really trying to understand and replicate this device.If you don't understand it, then is no point to continue, here or any other project, making a copy is not enough.
We have few people here that are really a goldmine for all, konehead, bolt, EMdevices, and few others, and I see many times that most of you are just ignoring their advices escpecially konehead who did try and built FE devices probably more than anyone here.
I have a great respect to konehead because I can see him thinking and building things same like me, not very sofisticated but simple and working and most important is that feeling that not everyone has.
Fake or not fake, this last 2 months showed to many of you a lot more understanding and knowledge than you have acumulated in a long time before, who can tell me that this is not true?
How many of you have experienced before this speed under load? How many of you have played before with coil shorting, capacitor shorting,... ?I am very happy that I brought up this discussions and now many people will start to understand it better.
Has anyone played with capacitors with 3 terminals? What about 4 terminals or 7??
Anyone tried to have 2 identical capacitors one charged and another empty.Now try to make a device that while is using first capacitor power it is charging the second one and end up with more in the second one.Possible??? oh yes it is.I have stated many times before, try easy and simple things before going big and before spending lost of money.I spend about £400-700 every month and i know most of you cannot afford that that's why keep it cheap and simple.
I wish you all the best,
Romero
So let me just resume this for a second. You deliberately faked both videos, you lied about the threats, you lied about not having your wheel anymore, you lied about the wheel doing what you said it does, you lied about knowing how it works because it does not and now, you want us to thank you for doing all this very generous effort of trickery just because since two months, "we are talking about this wheel".
So maybe if I put you in a prison cell, you will have to thank me because for the next two months you will be talking about how to use metal bars to create a secure environment. Or maybe you are willing to reimburse all those that will make a claim against you. Or maybe you just find all this very funny indeed. Or maybe you just love the idolizing. Or maybe you are so pissed off because your wheel did not work, that you are getting back at those that believe in such things. Either way, sir, you are a really sick puppy.
So what did we learn? Well. We learned that if you fake a video, people will eat it all up and end up treating you like a king.
You sir should be ashamed of yourself.
Now I have seen and read it all. I am simply disgusted.
wattsup
scratchrobot
Quote from: bolt on June 20, 2011, 04:52:05 PM
But most important you didn't have to build a 10 coil $1500  rotating STADIUM to find that out did you? :)  Well done!
I did build a replica right away  ;D
Thanks
