Muller Dynamo
Magluvin
Question.
We say that the motor accelerates under load, or short.
Would it be to say that we could get a motor running on just shorted coils? Of this fashion of course. ;]
Or is it that, if we have the rotor going at 1000rpm, gen coils not connected, just motor coils, does shorting or loading gen coils increase the rpm higher than 1000rpm?
Also, would the motor coils drive the rotor above 1000rpm(just example rpm) if the gen coils w/cores were removed from the setup?
Like this.  Lets say we get 1000rpm, gen coils unloaded, just motor coils. If the gen coils were removed, say we got 1300rpm. Is it that loading the gen coils close to simulates the same speed up as if the gen coils were removed? Or does it go faster with coils loaded than if the were removed from the device.
Hope that makes sens. ;]
Mags
romerouk
Quote from: wattsup on June 20, 2011, 08:36:34 PM
@Romerouk
The proof was already posted on this thread but Mr. Plengo removed them. You can see the whole thing here about proof.
http://www.overunityresearch.com/index.php?topic=1003.msg14812#msg14812
If you know me, you will know I rarely give up until the reality is freed. I also do alot of bench work although because of this wheel, I have been doing less. I work with ether attraction now so for me, these mechanical wheels are play things. One day I will share it also but not till I know all I need to know. So I don't need any life lessons from anyone here. I am here for one reason only and that is to find the reality for those guys like @peterae that are with builds and others that are contemplating on spending some serious money on this.
So for me it is clearer then clear. Magic is only magic until you know how the trick was done.
So here are some easy specific questions that you can answer with a yes or no. I am not asking you to give up any secret that is supposed to be in the Romero wheel.
1) In your first video of the large unit, did you connect the battery terminals to the dc output rail of the generator coils? Yes or No?
2) In your second video where you remove the battery from the table top, you have two wires, a red and a black wire that are behind the unit going down inside the center opening of the table? Yes or No?
3) Referring to #2, do those two wires go to a battery under the table or to any other power supply? Yes or No
4) Do you agree that applying a battery to the dc output rails will bypass any other physics phenomena because the load will always be driven by the battery. The voltage may rise because the gen coils are producing some more output by maybe 3-4 volts. That is why you were reading 15.?? volts off the output rail. Yes or No?
5) Did you willingly create these videos to trick people into thinking the device was working in a way that it was not? Yes or No.
6) If #5 is no, why did you make those two videos and especially why did you do it in the way you did? Did you think that eventually we would not have found the tricks?
Your problem is simple. Instead of coming here and saying you made a wheel that does not work the way you want and you need help to find out what to do. I would have opened all avenues to help you. But you decided to play this big game.
Now if you want to come clean, this is the time and this is the place.
Just know that the link above cannot be erased by this moderator.
wattsup
PS: Just saw your photo of your new build. Expensive, don't worry I know what expensive is. I have done bigger then those. 12,000$ just for a custom built gear system. But hey, it's only money, right. lol
Now one more thing. A person that gets serious threats to stop what they are doing, and who is really scared of those threats, does not continue to make a new build. You see the problem we have with what you say and what you show is always contradictory. Just come clean and let's start from the beginning.
First I can tell you that I am personally against deleting any posts, good or bad.In the end nobody can decide for us if it is good or bad.
Answers:
1) In your first video of the large unit, did you connect the battery terminals to the dc output rail of the generator coils? Yes or No? = Yes but not direct.
= No, those wires are going to the bottom coil.
3) Referring to #2, do those two wires go to a battery under the table or to any other power supply? Yes or No = No
4) Do you agree that applying a battery to the dc output rails will bypass any other physics phenomena because the load will always be driven by the battery. The voltage may rise because the gen coils are producing some more output by maybe 3-4 volts. That is why you were reading 15.?? volts off the output rail. Yes or No? = The output coils separately were producing much more than 15 volts but were kept shunted by a procedure I wont describe.That helped the system to maintain the rpm and not feel the load up to a point.There was a point where from normal speed will turn all the way down if added even one more watt to the system
5) Did you willingly create these videos to trick people into thinking the device was working in a way that it was not? Yes or No.  = No, I am not that kind of person you think I am, I have access to lots of servers, banks main servers, many important companies... If I am not trusted I will never walk in but maybe that is another thing.
6) If #5 is no, why did you make those two videos and especially why did you do it in the way you did? Did you think that eventually we would not have found the tricks? = Tricks? oh yes, there are many tricks but not that kind of tricks you think I did.
'A person that gets serious threats to stop what they are doing, and who is really scared of those threats, does not continue to make a new build.'
That you will not understand as you don't have the complete picture, if you will know, I am sure you will understand it and agree with me.I was interfering with others on the same project and we have a 'understanding'... if you look around you will probably find out soon who comes out with the same build and with a patent on it too.
Soon I am planning to invite some people from the forum for a live demontration.That will be enough to stop all this accusations. These people are very respectable here on the forum and most of you know them.
Don't wait to release any info on how will the new system work couse I wont.They can come over, video record for as long they want, can measure anything but without any o-scope,that will be forbiden.
I hope I answered all questions
Regards,
Romero
hhobrian
After reading and rereading about the rotor and magnet sizes, I was wondering if this diagram might be what we should be trying ?? Hope this makes sense, I suck with Paint etc., but shows 2 magnets in the rotor...
lasersaber
@romerouk
Thanks for sharing pictures of your new build.  I could tell that you were actively building a better unit this whole time.  I would have done the same thing myself if I were you.  I hate getting caught up in the stupid arguments that always happen on these types of forums.
I learned a lot when everybody tried to replicate my Stubblefield motor.  Most people failed and only a few got it working.  That was a very simple project compared to this.  I knew when I decided to replicate this device that my chances of getting it working like you showed in your video were very slim but I decided to build it anyway just because I love building things and this looked like a really cool motor.  Nobody should be complaining.  Nobody put a gun to our heads and said you have to build this thing.
I am still working on my replication.  I have taken it apart and rebuilt it more times than I can remember now.  I am still having a good time and learning a lot.  I plan on working on it until I stop learning new things with the unit.  I expect to have another few months worth of good learning with this project before I will start to tire of it.
nightlife
 The thing I don't think everyone understands is that when a unloaded coil is introduced, it will drawn the rpms down untill it is filled. While it is filling, it is representing a load, once filled, it no longer is a load and the rpms go back up just as this design does. The same happens when a cap is added to a coil. But I am seeing the rpms gain higher speeds after a coil is loaded then what they are before a coil is even introduced at all. This has me puzzled. Once I figure out why that is happening or someone else explains why, I can then determine weather or not it is actually a benifit or not.
Bottom line here is that there is no evidence of OU at this point but I am not giving up on you all yet. There are still some criticle things you all have left out of your designs that will double your potential output which I have already mentioned. Please use all the potential availible in the componets of your designs.
Last but not least, please show all results in watts. Volts mean nothing without knowing the amps. The cobination of them equals the amount of watts which is what we need to know to determine if a gain is actually present. Keep up the good work.
