Muller Dynamo
0 Members and 38 Guests are viewing this topic.
4Tesla
Quote from: coke2k on June 22, 2011, 10:56:08 AM
When magnetic field crosses the wire it induces a current , and when that current flow through that wire , it create a magnetic field with opossite direction than the primary field. Because of the Lenz  reaction. It is normal.  What will happen if we change only the magnetic penetrability of the space between two magnets,  There we will put a coils  and there we still will have a Lenz reaction, but will this reaction  affect to changing magnetic penetrability.  I think we should not rotate  the magnets, it's better  to rotate the soft iron washers.
Rawbush is working on something like this using magnetite:
http://www.overunity.com/index.php?topic=3842.msg292129#msg292129
e2matrix
Quote from: Mk1 on June 22, 2011, 10:57:48 AM
There are 4 ways to make a single wire unidirectional coil and 4 ways to connect them together ...
Most people ignore that fact except guitar maker (pickup coil) essentially the same thing romero is doing . Any guitarist can tell you why ...
I don't think he is canceling lens law , he is reversing it .
That rings true with some things I remember Romero saying.  Can you elaborate more on this please?
Mk1
Quote from: e2matrix on June 22, 2011, 11:27:28 AM
4 ways    clockwise going up
               clockwise going down
               counter clockwise going up
               counter clockwise going down
In guitar pickup you need to coil wound in the opposite direction to get a really silent sound . The magnet polarity is also reversed .
A guitar pickup coil is essentially a coil around a magnet or substitute (iron) with magnet added to the side .
Let just imagine it the lenz current was traveling in the opposite direction what would happen .
If you have 2 small dc motor connect them together and turn one , both turn ... now if they could work in the same direction .
I don't have much time right now to elaborate more .
if no current at all was returned to the coil , it would look like its not connected .
wattsup
Quote from: Mk1 on June 22, 2011, 11:45:35 AM
@MK1
I'm confused. Is it not.........
clockwise going up  =  counter clockwise going down  (same thing)
clockwise going down = counter clockwise going up  (same thing)
wattsup
PS: There are only two ways to wind a coil but there are four ways to describe the wind.
