Muller Dynamo
0 Members and 40 Guests are viewing this topic.
bolt
Quote from: Tudi on June 23, 2011, 05:18:08 PM
@bolt : i have a feeling you keep saying the same thing and most of the people keep not understanding it over and over again. Maybe if you could try to explain it differently.
Try do design a mathematic circuit. Just take a desider wire, give some coil size ( turns.. length...) calculate for that coil and specific RPM the cap size, draw in paint the circuit for it and post it here. I bet there are a lot more people who can copy paste then think deeply enough.
Thanks if you consider doing this.
i can not give practical wire sizes i haven't built one. Too many parameters of the magnetic flux to use simulators. I have posted scope wave shots identical to Romero scope shots.  I  already shown video examples so you can see the effect. People have said for years if only they could overcome Lenz and lugging they can make an OU generator. I have shown this, others have achieved it and rotors are now going FASTER with no LUGGING.  I dunno what more you want as proof!
altair
Quote from: bolt on June 23, 2011, 04:46:49 PM
Forget about the actual phase its about the relationship BETWEEN the current and the voltage needs to be 90 degrees.  As the RPM changes the angular relationship between the 90 degrees perfect offset will drift to a point where ZPE is no longer available and the system no longer reactive and drops back to old fashioned watts, heat, lugging and crap basically. Thane only see this from the point of high voltage i don't think he fully realised a low voltage high current coil can do the same if counterbalanced with large enough AC tuning capacitors.
Thanks bolt, I always see your posts just after I posted mine.
So basically, we need a system that conserves a relatively constant 90 deg phase shift between V and I.
I believe that the best way to experiment with this, would be to have the generator driven by an adjustable speed, feedback-regulated motor.
We adjust the RPM of the driving motor to the rate that gives the desired 90 deg phase shift between V and I and voilà !
A binary capacitor bank is not necessary because we just have to pick a single value of capacitor that will make our coil resonate at around the desired frequency, let's say 800Hz, and then adjust the RPM above or below that, depending on if we want the V to lead the I, or the reverse.
From there, all we have to do is figure out how to extract energy from that resonating system.  8)
Funny how simple that sounds... ::)
Something is missing.............. something is missing  :'(
I think I'll order stuff to begin experimenting , like all the others.
One more in the (endless) loop.
Sarcastically, Altair
bolt
Quote from: poynt99 on June 23, 2011, 05:33:37 PM
bolt,
Are you a HAM, and/or have radio electronics background?
.99
EE tech trained, Military comms, microwave, cellphone engineer, MOD contractor,  1980's CB'er/HAM. Old tube TV repair man yes i done a couple of jobs.
bolt
"Funny how simple that sounds...
Something is missing.............. something is missing"
Yea its called a Brain.
Tudi
Quote from: bolt on June 23, 2011, 05:40:27 PM
how much money would you need to take a vacation to have the time + buy the components to be able to make a device where you can make practical measurement and post at least a diagram as Joulseeker JT circuit ? ( might not afford it but who knows :) )
