Muller Dynamo
baroutologos
@Bolt,
Man, you keep repeating the same motto as if you are an answering machine or something. You must be aware, that your sayings (the full picture) does not make sense almost to no-one for a OU viable outcome.
We lack brains? Perhaps we do. If i were you, and had confidence in my theories and results, i would formulate a video series, much like zerofossilfuel, termed how to achieved OU out of a rotor-stator setup. Self explanatory, step by step video series, with measurments scope shots, etc.
Take your time, or this discussion about OU in ZPE and resonance and 90degree V I out of phase could be endless with 0 practical result.
What you say?
Scorch
In Consideration that timing is critical; maybe an electronic or centrifugal timing advance mechanism would be beneficial for maintaining perfect positioning of the switching?
Just a thought anyway.
If timing is so critical, then this is going to CHANGE every time you do something that changes RPM and the whole thing has to be re-tuned again for any particular load, voltage, RPM, configuration, etc.
Quote from: erikbuch on June 23, 2011, 11:42:23 AM
@all with a turning rotor
What happens if you,
when shorting coilpairs and get the increase in speed adjust your rotorspeed down to original speed either by adjusting voltage or by moving hallsensors.
If you do it by hallsensors you might get higher currentdraw if you place it right, Romero mentioned once that one of the driving coilpairs was used in both attracting and repelling mode.(A little bit of both, he said, i think this was in the experimenter thread)
Thus the high draw 0.94 amp. 1 drive coilset maybe actually holding down the speed ??
Maybe that instead of increased speed, one can get more out of the gen coils?
Just my 2 cents.
Cant do it myself until over this weekend, as of now Im still at work away from home.
Best regards
Erik
bolt
I really don't have the time right now i am already building an HHO genset and aiming for looping. Right now its taken 6 months of building and writing software for accurate timing control using AVR processor and currently it runs on just whiff of propane gas with 95% HHO  for 2kw load but cant quite close the loop .....yet.
www.sites.google.com/site/silverfreeenergy/home
I also said in the kapanadze thread if a couple of people come up with a bit of funding i will look into Kapanadze  solid state system. Two people have graciously sent me some donations yesterday enough to make a good start on that project. I have enough to order wire,  20 ferrite cores, basic HV control circuit etc so im going to be busy with that soon.
One of the reasons i did not get involved with the Muller is i knew on day two of its release tuning an understanding the design was going to be a pig and even if it did work 10 watts no good to me i need Kw's thus the reason for going to gensets and HHO. Already i can make a Kw of electric about 20 times cheaper than using gasoline so i have my safety net in place for when we lose the grid for whatever reason.
Tudi
Quote from: Chef on June 23, 2011, 06:17:54 PM
You need to give him 50 000usd  no strings attached if you want him to do that!  :D
There are still people on this world that do not live for money. I don't think 50 grand is much considering you would not need money for hopefully ever.
Quote from: bolt on June 23, 2011, 06:27:39 PM
Did not read about that, it seemed to me for a sec as an old trick my father used to steal electricity in the comunist days to make free vodka :D
But in case we put up a comunity donation link to sponsor people that are able make and will to make proper description how to replicate a theory i will surely join the club. At some point all will come down to the simplest way to make a device like this. I never trusted brown gas since my idiot neighbour might blow himself up. Apart from that, playing with fire is nice ?
altair
"Funny how simple that sounds...
Something is missing.............. something is missing"
Quote from: bolt on June 23, 2011, 06:02:39 PM
Yea its called a Brain.
Totally un-necessary insult.
F. Y.
