Muller Dynamo
0 Members and 92 Guests are viewing this topic.
Dbowling
Guys,
I have it on good authority that the secret will soon be revealed. Hold on just a while longer. ONE OF US knows the answer!
NOT ME!
David Bowling
David70
@bolt
I did't mean it but i hate that atitude from @aircore
I need to see the clue like everyone here.
penno64
We have the man's blessing! ( I was not teasing anyone)
Please do NOT bombard me with questions or PMs. I mean please.
What I have found is that this will only work with multi filar coils.
How many of you guys have watched Thane's videos. How is it that his rotor speeds under load.
I am not telling you how to do this - you can find that on your own, but
What I did was using a 5 x 0.2mm wound coil is seperate and identify the wires.
Use some as normal but try and wire one or two differently.
I used two - start - stop join two more - start stop, just like tesla's coil and wire the last start from the middle of the bifilar join to stop.
Try it and see.
I guess a pic or drawing would be good, but I need to go now.
I will draw one later and post.
Patience and determination.
Penno
mariuscivic
Hy guys!
I finally cleaned out the output signal. I found out that the 2 wires that connects the bridge rectifiers , don't have to be put random.
Here are two shots  of the previouslly signal and the curent one.
Also , i put all the diodes in parrallel on the BR and does have some effect in speeding the rotor in dead short.
bolt
i have mentioned Thane many many times here recently. I explained why there is a narrow bandwidth of rpm versus load to achieve a small window of OU condition. Please don't get caught up in Thanes special flux paths i think he even realised now its a serious distraction. In addition you don't need HV coils,  LV coils can do the same thing when wired correctly and given the correct magnetic bias.
