Muller Dynamo
0 Members and 83 Guests are viewing this topic.
4Tesla
I think ground meaning 0v??
Arthurs
Quote from: lumen on June 26, 2011, 12:07:12 AM
Ok, this could be the answer if you get this.
An 8 strand litz wire is wound as a regular coil and one end is soldered all 8 wires and is the ground connection.
The other end is separated into two wires with 4 in each wire. This makes 3 wires to the coil total.
When the magnetic field enters the core, current will flow and one 4 wire set will be + with respect to ground and the other will be - with respect to ground.
Because current is flowing in opposite directions down the 4 wire sets, Lenz will also be in opposite directions and is then cancelled.
You just use the two 4 wire sets to the FWB  along with 4 other diodes to ground? and you get zero Lenz effect.
This is very close to what works!
Hi lumen:
    You can use the diagram shows?
    So that we fully understand what you mean.
    Thanks in advance.
Artist_Guy
He said 7 strand Litz originally?
4Tesla
Quote from: Artist_Guy on June 26, 2011, 02:11:00 AM
Maybe because that is all he had.. I would think an equal 4/4 would be better.
You can get 8 strand Litz here:
http://www.surplussales.com/wire-cable/LitzWire.html
4Tesla
Quote from: Charlie_V on June 26, 2011, 01:00:35 AM
Lumen,
If I'm understanding this correctly, there are two wire groups (each group with 4 wires) and the two groups are soldered together at the end.  If this is correct, then I'm pretty sure that when a magnetic field enters the coil core, both wire groups will generate + with respect to ground.  I don't see why one group would be - with respect to ground?
Good question.. I would like to know if this does cancel lenz.. has anyone tried.. or just a theory?
