Muller Dynamo
0 Members and 268 Guests are viewing this topic.
Dave45
cool video ,  so if the high voltage coil (regenerative coil) stores energy inside couldnt we wrap the coil with Mylar in between the windings and increase its capacitance
is this what Lasersabre did with his coils
Bruce_TPU
Hello ALL,
I have just this evening, returned from my journey.  I had the privilege of visiting Coral Castle, and speaking with someone who knew Ed.  I have a myriad of photos and some interesting new "items" to put out there, but will do that in another thread, within the next few days!  Also working on my TPU!
Let's talk "strands"....(litz)  Funny, how I mentioned this over 200 pages ago (and in the last few pages of my thread) and it has come up again.
Penno and all, how many turns did Romero say he had on his bobbin?  Over 300 turns.  Everyone's comment was, "he is mistaken, that many turns can't fit!"  Wrong!  As I explained in my thread, before Romero ever had his device working, as I explored the statement's of Steven Mark, about parallel wires, you can take litz wires and wire them in series or parallel.  The "potential" (total wattage) will not change, but wired in series you end up with MUCH HIGHER VOLTAGE.  And I think a few of you were wondering "how" Romero achieved this.
In the experiments presented by Slider (yes, I have been reading while on my journeys...) and spoken of by Penno, what they are calling a "bifilar" wound, is what I call "series" wound.  Some are in parallel but some are in series.  Let's assume that your 7 strands gives you just over 100 turns on your bobbin.  Now, let's say you connect the wires, 123 ends to start of 4567, you now have 200 turns and have doubled your inductance (air core, then adding inductance of ferrite core)but raised your resistance.  Inductance trumps resistance for wanting higher voltage.  Now, let's go with Romero's winding, of say 300 turns, then to achieve that, please do the following, and you too will end up with MUCH higher voltage (lower current.  Current causes LENZ, NOT voltage).
Wires are (a) for start and (b) for end...  Take wires 1a and 2a, and connect together.  This will go to your FWBR.  Take 1b and 2b and connect to 3a and 4a.  Connect all four together.  Next take 3b and 4b and connect to 5a, 6a, 7a.  Connect all 5 wire ends together.  Next take wires 5b, 6b, 7b and connect to other side of FWBR.  Now you have 300 turns and MUCH higher voltage!   ;)
Hope that helps ya'll.
Cheers,
Bruce
Magluvin
Quote from: Bruce_TPU on June 29, 2011, 09:46:37 PM
Hello ALL,
Cheers,
Bruce
But no mention of increased capacitance?  Romero said we needed to increase the capacitance. He stated that we could just use regular coils and add a cap.  But he also stated that we could get it by having the coil in a different configuration. ;]  bifi. I stated that and he confirmed it. If anyone should know, its Romero. He had the working model.
here is my post on the 14th
http://www.overunity.com/index.php?topic=11009.msg290900#msg290900
And here is Romeros post just after mine
http://www.overunity.com/index.php?topic=11009.msg290925#msg290925
So why is the capacitance not important Bruce?  I think its key.  So says Romero.
Mags
e2matrix
Hello ALL,
Cheers,
Bruce
Funny that is exactly what I was thinking after watching the video tanakat just posted here: http://www.youtube.com/watch?v=Z1weXYivARo  from ThaneCHines and his talk about Lenz and voltage and current all lead me to the conclusion that what you just said Bruce is very important.  I do know it's been discussed before and some have been leaning this direction in the last couple days since Slider shared his demo but I think it just really sunk into my own head after seeing Thane explain things about Lenz in that video.  I think this is definitely an IMPORTANT part of getting this to OU.
e2matrix
Mags,  R didn't use caps on his looped setup did he?  Other than the big one on the output.  So wasn't he saying this is just another way to get the effect or maybe enhance it?  I think it may be just yet another way to get around the problem of Lenz.  Litz or Lenz - what's it gonna' be?  You can't have both - hehe
Just had to say that that way so now maybe I'll remember it  :)
